Shop Lighting Question
Forum topic by Stacey posted 235 days ago 469 views 1 time favorited 19 replies Add to Favorites
View Stacey's profile
Stacey
19 posts in 238 days
235 days ago
I am in the process of building my new shop and had a couple of questions. I am currently working on getting the siding up as my helper is available (the wife!) and am working on the wiring right now which leads me to my question: What type of lighting do most of you have or would like to have? The shop is 18’ x 32’. I was thinking of 2 rows of 8’, T8 Fluorescent lights run the length of the building with 3 lights per row. Sound good? Too much or not enough? Thoughts or recommendations.
Thanks,
Stacey
-- S. Box --- "But a Constitution of Government once changed from Freedom, can never be restored. Liberty, once lost, is lost forever." - John Adams
View Red Headed Merganser's profile
751 posts in 656 days
235 days ago
You can never have too much light, in my (getting a little older and noticing when it is darker in a room) eyes. And the more natural the light the better. I think those T8s are pretty close to natural, aren’t they?
You should also consider one or two portable lights you can use to create raking light when you’re checking for sanding marks.
-- Ethan, http://www.merganserwoodworks.com, http://greystonegreen.blogspot.com/
View GaryK's profile
GaryK
8482 posts in 470 days
235 days ago
I have about 20, 4” standard Fluorescent lights. I got them because I have a lot of shop to light and they were
the least expensive things out there. I think Lowes had the fixtures for around $10 each.
I have 3 rows of lights and each row is controlled with a separate switch. That way I don’t have to light
up a part of the shop I’m not using.
View Sawdustmaker's profile
Sawdustmaker
254 posts in 279 days
235 days ago
Although I have a number of the standard 4’ – 40 watt fluorescent bulb fixtures and the price is right, I’ve started purchasing the newer T8 Florescent lamp fixtures when I need more light. The fixtures are a little more compact and the bulbs are 32 watts vise the standard 40 Watt. Look for a Daylight bulb with at least 750 lumen for your best light to work under. I also have a few tripod work lights that have a 500Watt and a 250watt light in them. They eat allot of power but they come in very handy for applying finishes. They do put out a fair amount of heat so keep your flammables at a respectable distance. If you’re going to be using a lathe, you might want to look for a fixture that has a lexan cover so you don’t get showered with shards of glass in the event your stock takes flight.
-- Brian, Virginia Beach
View whit's profile
whit
25 posts in 459 days
235 days ago
I have a shop about that size (16×30) with 9 shop lights (3×3, 2-bulb, 4-ft). I originally had 2 rows of lights and ended up spreading them apart and running a third row down the middle. I’m in the process of replacing them with standard 4-tube, T8, 2×4 troffers. I’m finding that the shop lights just don’t put out quite enough light – or . . . that my old-man eyes just seem to need more of it. They also don’t work worth a hoot when they’re cold (basement shop, N of Atlanta). I’ll probably also switch them by zone; right now they’re all on one circuit.
-- Even if to be nothing more than a bad example, everything serves a purpose.
View roman's profile
roman
439 posts in 375 days
235 days ago
I have 4 high pressure sodium lights?....big round expensive but lots of light, bulbs last 20 years or more and energy efficient.
Also 5 LEDs for night lighting so I dont break a leg going in when its dark
View Dadoo's profile
Dadoo
1536 posts in 472 days
235 days ago
I use fluorescent bulbs in my garage/shop. They seem to work quite well too. I’m interested in Roman’s sodium lights too as anything that saves power these days is always welcome. Would be worth checking out anyhow.
Here’s a suggestion too: Be sure to install your lighting on a totally separate breaker so when you “blow a fuse” on the saw, you’re not in the dark as well.
View cabinetmaker2's profile
cabinetmaker2
35 posts in 245 days
235 days ago
I bought 4’ home cheepo/depot fluorescent lights, they come with a 6’ cord with a plug on the end, I wired my shop ceiling with outlet boxes and installed an outlet every place I had a machine, then added a few extra down the middle, now I can plug in the light, if I need to move any I have 6’ of cord and outlets within reach ,I can add lights, take away lights,pretty much do what needs to be done, also gives me places to plug in other things like my shop vac, and anything else I may need power for. I would like to buy a better light, but thats down the road aways, money is tight this time of year. but the lighting I have works great…..
-- Mark, Hancock Maine, rmarkham52@hotmail.com
View Blake's profile
Blake
2000 posts in 356 days
235 days ago
Make sure you have some direct “task lighting” as well. Point a few spot lights over the places you concentrate, like over your scroll saw, bandsaw, table saw, bench, etc. I think having a variety of different types of light spectrums and intensities is good for the eyes and good for the brain. You don’t want your entire work space to be awash with fluorescents.
-- Check out my new website! http://www.theeasellife.com
View 8iowa's profile
8iowa
114 posts in 243 days
234 days ago
Stacey:
I built a new 24’x28’ shop in the U.P. last Summer. On separate circuits, I first installed six equally spaced std incandescent fixtures with 150 watt bulbs in each. On the other lighting circuit I mounted nine fluorescent fixtures in three rows. Each fixture has two 4’ T-8 bulbs. By all means, treat yourself to the new electronic ballast type lights. The old type magnetic ballast fluorescent lights operate at 60hz, well within our visual and audible range, thus they hum and flicker. They have even been known to produce a strobe effect on rotating machinery. Actually some people are adversly affected by the old style magnetic ballast lights, suffering eye strain and headaches with prolonged exposure. On the other hand, the new technology electronic ballasts function at 21,000hz, thus there is no hum or flicker – this frequency is above the human range of sight or sound. Yes. The old type fluorescent fixtures are cheaper – but it would be a shame to install them in a new shop and be stuck with the old technology fluorescent lighting.
There are two indices of bulb rating that are important to be aware of. On the packaging of most fluorescent bulbs, a degrees Kelvin number is shown, and also another CRI number (color rendering index). Bulbs closest to 5000 degrees Kelvin more closely approach natural light. Bulbs with a CRI closest to 100 will display colors more naturally. (Incandescent bulbs have a CRI of 100.) When you shop for fluorescent bulbs keep these rating indices in mind. You will quickly see that the old “cool white” bulbs that we used in the past do not measure up very well. Actually, you will usually also see terms like “cool white”, “daylight”, “sunshine” – the only thing that accurately describes a bulbs characteristics are the two above indices.
A mixture of incandescent and fluorescent is not a bad idea for a small shop. You can still save energy and maximize both the degrees Kelvin rating and the CRI.
View gizmodyne's profile
gizmodyne
1479 posts in 572 days
234 days ago
Put as much as you can fit. It won’t seem like much as you are working. I have 6 eight footers in a tiny shop. It is perfect, though task lighting is needed as well.
I have mine switched so I can turn the middle row on or the outside rows or both.
Dadoo
234 days ago
Skylights. Solartubes.
View Kirk's profile
Kirk
31 posts in 536 days
234 days ago
Stacey,
I have a 30’x40’ and I have put 12 4’ lights around the perimeter. I even place one at the overhead door. I am considering put some down the center, but as of yet I don’t need them.
The lights wash the walls, therefore, I don’t have shadows when working at a machine that is against the wall.
-- W. Kirk Crawford - Tularosa, New Mexico
View DaveH's profile
DaveH
241 posts in 260 days
232 days ago
I wouldn’t go with an 8’ fixture unless it uses 4’ tubes. It is a pain to break up an 8’ tube for disposal. I’d also be sure to get electronic ballasts with T8 bulbs for instant startup and better light. I believe you need from 24,000 to 30,000 lumens to light a 1000 sf shop with white walls (10 foot high ). I believe thats 16 to 19, 4foot, 32watt fluorescent tubes. Can anyone verify this for me?
-- Dave Herron, Boise, ID -- “That which does not crash the browser, makes it stronger”
View Dave's profile
Dave
24 posts in 260 days
232 days ago
I have 4 of those 4’ flourescent lights that I got at home depot for about $10. I wired 4-outlet receptables into the ceiling joists…I just unplug the light if I don’t want to use it, but I did wire a switch to control all of the lights in case I want to leave them plugged in and turn on the entire basement. I tried to space them no more than 4 feet apart for maximum lighting, like others have already said, you can never have too much light. And as you get older your eyes will appreciate this. And make sure to place one directly over the main area that you will work at (sitting at the workbench, over the saw area, etc…). Good Luck !
-- You gotta laugh a little...
GaryK
232 days ago
Here is a photo of my shop under construction.
Three rows of lights each on a separate switch. This photo was taken at night.
The shop is 25 feet wide by 40 long.
View mgradwohl's profile
mgradwohl
110 posts in 295 days
232 days ago
Check out my post about my shop. I have T8 lights, they are 8’ long, 2 lights per fixture, and I have something like 9 fixtures. It is great lighting. No hum, flicker, or eye strain. My are bolted right to the ceiling. I bought a case of good bulbs when I put them in, and just replaced the first one today after 6 years.
View Sawdust2's profile
Sawdust2
847 posts in 569 days
231 days ago
I, too, opt for T8’s. 835’s give the closest to daylight.
There was an article in FWW about 2 years ago, when I did my shop. It recommended T8’s and my recollection is that they should run in line the length of the shop and be spaced about 5’ apart side to side. So 2.5 feet from the wall, 5’ spacing.
Go to www.finewoodworking.com and enter lighting for the search. They presently have a free 14 day trial and you can download all the articles on lighting you want.
View Dave's profile
Dave
230 days ago
One other think you might think of is to paint your walls (or pegboard) with a glossy white, and if possible, tile your ceiling or drywall and paint it white. The flourescent lighting will be much more enhanced. I painted my pegboaard with a high gloss white, not only does it help with the lighting, but it helps me find my tools easier.
Stacey
230 days ago
Thanks everyone. I picked up my light fixtures today at Lowes. I am going to run 3 rows of 8’ T8 fluorescents lengthwise. Each fixture uses 4 4’ lamps which I thought would be easier to change and dispose of. I’m going to start wiring this weekend. I have a couple of wiring questions but rather than post them here, I will post a new topic so it gets more exposure. Thanks again to everyone for their advise.
Best.
Bookmark And Share This Page
