Bench Cookies and Dust Collectors
Forum topic by DaveConry posted 11-30-2010 05:21 AM 1467 views 0 times favorited 4 replies Add to Favorites Watch
View DaveConry's profile
DaveConry
66 posts in 3599 days
11-30-2010 05:21 AM
Just in case you were wondering…...yes a dust collector will suck up a bench cookie from the bench. I was brushing chisel shavings from my benchtop into the open hose on my dust collector, when my grandson dropped a bench cookie right at the end of the hose. I found it laying in the ‘Y’ fitting below the fan housing. I can only imagine the mess had it gone thru the fan.
-- Evil can only thrive when good men do nothing.......E. Burke
View jusfine's profile
jusfine
2422 posts in 2827 days
#1 posted 11-30-2010 06:07 AM
Sounds like the system has good suction!
What are they made of? Have never used one.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View cabs4less's profile
cabs4less
235 posts in 2664 days
#2 posted 11-30-2010 06:19 AM
thats hilarious hey dont feel bad one of my ex employee used mine to vacum nails and screws from my tool bag sounded like a war in the fan box
-- As Best I Can
View PeteMoss's profile
PeteMoss
207 posts in 3371 days
#3 posted 11-30-2010 01:38 PM
I have to admit that mine digested a full shop apron quicker than I could do anything about it. Luckily it’s a cyclone and it went into the barrel rather than the fan. I’m sure it would have been disastrous otherwise.
-- "Never measure......cut as many times as necessary." - PeteMoss
DaveConry
#4 posted 11-30-2010 09:55 PM
Randy….yes it sucks so good that I didn’t figure I needed a cyclone. Looks like I may have to get one if for no other reason than to protect the dust collector. A bench cookie is just a plastic disc about 3” in diameter and an inch thick. It has a rubber pad on each side. You put them between your benchtop and whatever you are working on to keep it from sliding around the benchtop. I use them while sanding, chiseling or hand planing. They work great. You can find them at Rockler, Woodcrafts or even Home Depot.
Cabs and Pete…...sounds like a cyclone or something to catch heavy items is a good idea. I have seen guys take a bucket and put a couple of fittings on opposing sides to catch anything larger than shavings. I might try one of those first.
