When wood turning, why is my wood checking?
Forum topic by BassBully posted 905 days ago 1397 views 0 times favorited 4 replies Add to Favorites Watch
View BassBully's profile
BassBully
258 posts in 2267 days
905 days ago
Topic tags/keywords: lathe wood turning checking
When wood turning bowls, the end grain section always seems to contain checks or pits in the wood. This is quite frustrating because it seems that the only way around it is to sand the piece to death. My first instinct is to check the gouges to make sure they are sharp and they are. That said, I use a General International grinder with a pretty fine stone for sharpening. I’m not sure the grit to be honest but what should I be using there? Any other tips for sharpening? I’m pretty competent at sharpening as I also sharpen my woodcarving knives and don’t run into problems there.
My next thought is the wood that I’m using which is spalted maple. That said, maple is typically a fine grained and strong wood but could the spalting have something to do with weakening the wood?
Then, I’m using a Barracude2 wood chuck from Penn State Industries. This chuck has had great reviews but I seem to have a few problems with it. Again, this could be all my fault but my typical problem is that when I turn the bottom of the bowl, then flip it over and put it in the chuck, it doesn’t seem to rotate exactly on center and always has a slight wobble.
I would blame my lathe but I have two and run into the same problem with both. My first lathe was a Jet mini lathe and my new one is an Old Delta 46-450 12” wood lathe that I recently purchased for $150. It seems to be in good shape though.
Thank You for any advice on this.
-- There are three types of people in the world, those who can count and those who can't!
View lew's profile
lew
8986 posts in 1925 days
#1 posted 904 days ago
Have you tried adding a bowl scraper to your turning tool arsenal? For me, the scraper is very effective for removing wood and leaving less to sand- but I still have to sand!
Also, I have read about lightly spritzing the wood surface with water. It is supposed to raise the end grain to allow more effective cutting. Although, I admit I haven’t tried it.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View Roper's profile
Roper
1333 posts in 1883 days
#2 posted 904 days ago
Where do I start, spritzing the wood is a good way of getting rid of the small surface cracks, I sharpen my gouge once right before I am finished, I do one final cut and I am done. As for the wobble you speak of make sure that the shoulder on your tenon is fitting inside the chuck properly, if its to big or to small it will not fit and will want to walk out of the chuck.
-- Roper - Master of sawdust-www.coloradocustomworks.com
View Big_Bob's profile
Big_Bob
158 posts in 1879 days
#3 posted 903 days ago
BassBully
It sounds like you may have two problems.
I would suspect you are getting tear-out that would explain the pitting. Usually that is a technique issue. Use of a bowl gouge is not an easy skill to master, but when you do you become a great fan of the bowl gouge. A properly cut bowl bottom will need very little sanding. As for the bowl scraper, remember it is just a finishing tool. If you dig deep with a scraper you will also get tear-out.
The cracking could be from the heat build-up during the sanding process. Also, never try to sand-out the tear-out (pitting) that just creates more heat and more cracking. You will grow old trying to sand out the tear-out.
I would suggest you look for someone to work with you. It looks like you are near Des Moines, Iowa this link can help you find the woodturning club in Des Moines. http://www.woodturner.org/community/chapters/LocalChapters.asp#75
A club is a great place to improve your woodturning skills.
-- Bob Clark, Tool Collector and Sawdust Maker
BassBully
#4 posted 902 days ago
Thanks guys. I’ll give those things a try.
