Messed up my Mortises
Forum topic by wseand posted 11-30-2010 01:09 AM 1338 views 0 times favorited 17 replies Add to Favorites Watch
View wseand's profile
wseand
2796 posts in 2948 days
11-30-2010 01:09 AM
Topic tags/keywords: question alder joining
I have accidentally made several of my mortises about an 1/8th plus too deep. Do you all think I need to fix this or can I get away with leaving it the way it is. Not the best pic but hopefully it helps.
17 replies so far
View dbhost's profile
dbhost
5686 posts in 3138 days
#1 posted 11-30-2010 01:14 AM
I fail to see a problem there except that the sides of the mortise are exposed.
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View Roper's profile
Roper
1384 posts in 3619 days
#2 posted 11-30-2010 01:17 AM
You can always glue some veneer strips in to fill the gap.
-- Roper - Master of sawdust- www.roperwoodturning.com
wseand
#3 posted 11-30-2010 01:25 AM
Yeah I messed up on that too dbhost. I wasn’t thinking at all. Fortunately they will not be exposed. I am trying to whip out four bookcases by Christmas, and I am rushing. Bad idea.. I think I will throw some veneer in there and move on. Thanks gents.
View richgreer's profile
richgreer
4541 posts in 2981 days
#4 posted 11-30-2010 02:05 AM
Can you cut the shoulders back a little to make it fit better?
View Howie's profile
Howie
2656 posts in 2829 days
#5 posted 11-30-2010 02:22 AM
Cut a thin slip of wood and insert in the bottom. Sand it and it will be fine.
If you take a poll you will probably find out we all have done that at one time or another :-)
-- Life is good.
View CampD's profile
CampD
1628 posts in 3393 days
#6 posted 11-30-2010 02:42 AM
like Howie, cut thin strips to fit the gap, I have used the cut-offs from cutting the cheeks, usually fit good
-- Doug...
wseand
#7 posted 11-30-2010 03:00 AM
I have glued some pieces in the bottom there and waiting for them to dry. I may need to clean them up a bit. I figured it wouldn’t hurt and it is better than just living with it.
@rich These need to be at 1/2” but if I pushed them out half the distance it wouldn’t actually cause that much of a problem if I did it to all the stiles.
@GW, I figured I would hate myself if I didn’t clean them up, I try to get them as tight as possible. I like to see the glue on all surfaces. But, I am learning as I go.
Thanks again Gents.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3013 days
#8 posted 11-30-2010 03:41 AM
Don’t worry about it. All the strength is in the cheeks anyway. I leave a 1/16-1/8” open in the bottom for the glue so it doesn’t push out as much.
View ChuckV's profile
ChuckV
3096 posts in 3434 days
#9 posted 11-30-2010 03:48 AM
The bottom is really not important. Think of a through M & T joint – there is no bottom to the mortise! Another reason to leave 1/16” or so at the bottom is in case the piece with the mortise shrinks. You do not want to have anything break.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View PurpLev's profile
PurpLev
8534 posts in 3555 days
#10 posted 11-30-2010 03:58 AM
the bottom has no mechanical strength as it is end gain to long grain – not really a good glue joint anyways. actually, many people leave an extra 1/8” at the bottom of the mortise for excess glue to drain to.
wseand
#11 posted 11-30-2010 04:05 AM
Very good points the next ones will be a little looser at the bottoms. I guess I always figured the tighter the better. I do forget about movement and keeping a little of that glue in there. This project I am attempting to go without any screws or nails, well maybe some pins. Why did I say, “by Christmas no prob”.
Thanks again Gents.
View Brian024's profile
Brian024
358 posts in 3306 days
#12 posted 11-30-2010 05:29 PM
That’s what mine look like all the time, never worried about it.
View poopiekat's profile
poopiekat
4325 posts in 3641 days
#13 posted 11-30-2010 06:04 PM
Ditto on the little tapered wedges. Makes a bad joint look lots better.
View TheGravedigger's profile
TheGravedigger
963 posts in 3931 days
#14 posted 12-01-2010 05:56 AM
The key on a mortise and tenon joint is to have a smooth – not tight – fit. There has to be just a hair of room for the glue film. Find a YouTube video (or one here) of someone that has made a good joint and watch how it goes together. You’ll get the idea of the kind of fit you need.
-- Robert - Visit my woodworking blog: http://littlegoodpieces.wordpress.com
wseand
#15 posted 12-01-2010 06:03 AM
Thanks Robert I plan to do some more research and some more practice. I always think I am doing it right till I have to fix it. 8~)>
