What to do with this ash?
« back to Woodturning forum
Forum topic by BenDupre posted 06-05-2017 10:24 PM 757 views 0 times favorited 9 replies Add to Favorites Watch
View BenDupre's profile
BenDupre
677 posts in 608 days
06-05-2017 10:24 PM
Friend just cut down an ash tree (stupid bugs!) and sawed down these blanks for me. Tree was dead but this still feels wet and is very heavy. I plan to turn some handles and maybe a few rolling pins.
I have been turning for a couple years with store bought blanks. Sometimes dry sometimes they are encapsulated in wax. Is ash better to turn wet or dry?
Knowing i cant turn all this now what should I do?
Put it up and let it dry? How long?
Seal ends with wax?
Seal the whole stick in wax?
Is there anothwr product besides parafin i should think about using?
If i turn wet what are some pointers to help keep it from checking after its turned?
Thanks for advice jocks!
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
9 replies so far
View BobAnderton's profile
BobAnderton
283 posts in 2910 days
#1 posted 06-05-2017 10:57 PM
Seal the ends with Anchorseal, which is a wax emulsion. You can get it from Amazon or Woodcraft or the like. The pieces that have the pith in them (if any) are likely to crack but the ones that don’t contain the pith should dry fine. Stack them with pieces of 1×2 between them and give them a year or so
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View TheDane's profile
TheDane
5516 posts in 3783 days
#2 posted 06-05-2017 10:59 PM
Ash makes nice handles, spindles, etc. I prefer to turn it dry, but that’s a matter of personal choice,
I would seal the ends … don’t seal the whole piece. Sealing the ends will slow down drying and reduce checking/cracking.
Paraffin is fine … I use melted candle wax (I buy candles at a local resale store).
View doubleDD's profile
doubleDD
7646 posts in 2163 days
#3 posted 06-05-2017 11:31 PM
Good advise above. It would be a bit easier to turn somewhat wet but you always have a chance that it may warp on you after your final shape. I received a lot of Ash from a tree across the street and it was somewhat wet. I cut it int some usable pieces and a few months later it was ready for anything. Beautiful lumber.
View Jim Jakosh's profile
Jim Jakosh
21114 posts in 3225 days
#4 posted 06-06-2017 12:39 AM
Seal the ends with Anchor Seal, let a dry a while and then make baseball bats our of it!!
Jim
View AlaskaGuy's profile
AlaskaGuy
4369 posts in 2429 days
#5 posted 06-06-2017 12:48 AM
Are there any bugs in your ash?
BenDupre
#6 posted 06-06-2017 01:11 AM
- AlaskaGuy
Um.. howdo I know that?
View TravisH's profile
TravisH
609 posts in 2055 days
#7 posted 06-06-2017 01:48 AM
Ash borer is regarded as benign when it comes to interior wood. Its larvae bores under the bark.
Typically trees can be sent to sawmills within the quarantine area or have sawyers bring their portable sawmills to the site. Once cut into lumber, the trees aren’t an issue in regards to emerald ash borer and make their way into furniture, flooring, etc…
BenDupre
#8 posted 06-06-2017 01:51 AM
Typically trees can be sent to sawmills within the quarantine area or have sawyers bring their portable sawmills to the site. Once cut into lumber, the trees aren t an issue in regards to emerald ash borer and make their way into furniture, flooring, etc…
- TravisH
Thanks!
View hairy's profile (online now)
hairy
2750 posts in 3652 days
#9 posted 06-06-2017 12:22 PM
When I turn firewood into blanks, I Anchorseal the ends and write the date, weight and species on the blank. After a few years in storage, different types might start to look alike. Also write moisture content if you can.
When the blank stops losing weight, it’s dry.
Ash is great for spoons and kitchen implements. It will not impart a flavor to the food. Much easier to work wet in this case.
-- My reality check bounced...
