Overhead Table Saw blade guard- good or bad?
Forum topic by Tooch posted 06-05-2017 12:42 PM 3500 views 0 times favorited 22 replies Add to Favorites Watch
View Tooch's profile
Tooch
1856 posts in 2114 days
06-05-2017 12:42 PM
Topic tags/keywords: question jig safety
Here’s a safety question for everyone, which is going to probably evoke some strong opinions from people either way.
When you are using a table saw, do you use an overhead blade guard?
Personally, I do not. The one that came with my Sawstop PCS 3.0 feels to be very flimsy, and inhibits my view of the rotating blade. Now I fully understand their intended use—to both protect the user from chips/splinters, and foreign objects falling on the blade—but I find them to be more of an annoyance than anything and actually decrease my feeling of safety when they are in use.
Also, there are a couple other issues I face with overhead blade guards. When making thin rips (less than 1-1/2”) I feel like I cannot use the guard and a push stick effectively. Dado cuts are impossible to do with the overhead blade guard since the splitter is taller than the blade (as opposed to a riving knife, which sits at the same height as the blade).
I did a quick YouTube search and found varying opinions, so I was interested in all the LJs take on this. here’s probably the closest opinion to match my own, found from a WWMM vid:
https://www.youtube.com/watch?v=tigNb2TD4-s
-- "Well, the world needs ditch-diggers too..." - Judge Smails
22 replies so far
5236 posts in 2731 days
#1 posted 06-05-2017 02:31 PM
I have a Sawstop, and sold the overblade guard piece. I have an Excalibur mounted on the saw, and it is always in place when I’m sawing unless it’s with a tenoning jig or other cut that makes me move it out of the way. My dedication to that type of guard is for the dust collection capabilities, and the puny opening on the SS OEM wasn’t going to cut it (IMHO).
View Gene Howe's profile
Gene Howe
11149 posts in 3666 days
#2 posted 06-05-2017 02:35 PM
Took mine off long ago. Would like an over arm set up for DC, though.
View Monte Pittman's profile
Monte Pittman
30145 posts in 2576 days
#3 posted 06-05-2017 03:26 PM
With everything I cut, the blade guards interfere too much with many of my projects. That being said, I work alone. If I had employees, I wouldn’t allow them to work without all safeties in place.
View syenefarmer's profile
syenefarmer
519 posts in 3318 days
#4 posted 06-05-2017 03:27 PM
Also stopped using mine for basically the same reasons you stated plus it was always a hassle to realign the splitter with the blade whenever I was done making a dado cut. They certainly do have their purpose where safety is concerned but if one is always aware of using the table saw safely they shouldn’t really be necessary.
View Woodknack's profile
Woodknack
12464 posts in 2618 days
#5 posted 06-05-2017 04:10 PM
Blade guards are a legal device, not a safety device. But like Gene I would like to have an overarm dust collector.
View Jim Jakosh's profile
Jim Jakosh
21961 posts in 3343 days
#6 posted 06-05-2017 04:37 PM
I never used mine since I got my saw. I cut so many shapes and use lots of sleds that I’d spend more time taking it off and putting it one than time cutting. I spend enough time changing the insert when doing angle cuts!!
If I was always doing flat cuts, I’d use it because it keeps the chips/dust from flying at you. I always wear ear and eye protection on the table saw, though. I don’t mind dust in my hair but not in my eyes!!
Cheers, Jim
Tooch
#7 posted 06-05-2017 05:08 PM
thanks guys, lots of good opinions. I think the overall opinion is that if it weren’t such a hassle it would be more practical. I’m not setting aside the safety issue; with a riving knife (which I use) I feel like kickbacks can be prevented.
View unbob's profile
unbob
810 posts in 2141 days
#8 posted 06-05-2017 05:25 PM
The Excalibur guard on this Delta 12-14 is easy to use, I lift it up for sleds. It can be quickly removed if needed, but its heavy.
View hoss12992's profile
hoss12992
4106 posts in 2131 days
#9 posted 06-05-2017 05:49 PM
I don’t use one as I view it as a safety issue and feel I’m much safer using my table saw sled whenever possible. Much faster and allows for better accuracy. A lot of stuff I cut I would have to remove it anyhow to make the cuts
View Carloz's profile
Carloz
1147 posts in 829 days
#10 posted 06-05-2017 05:54 PM
With the blade guard the amount of dust in the air is very noticeably lower even without dust hose and is very much lower with the attached dust collection.
View Redoak49's profile
Redoak49
3740 posts in 2227 days
#11 posted 06-05-2017 05:56 PM
I do not know why anyone needs a blade guard or riving knife. I am 100% focused on safety and that will protect me. Besides the blade guard causes safety problems at times.
I just wanted to add this comment before someone else did.
View TheDane's profile
TheDane
5575 posts in 3901 days
#12 posted 06-05-2017 06:07 PM
I have a Sawstop PCS with the over-arm guard, and use it pretty much all of the time. The dust collection alone makes it worthwhile.
The only time I don’t use the over-arm guard is when I am making a non-through cut (e.g. have a dado stack running, etc.) or am using a sled.
I also use push-sticks and featherboards.
View Loren's profile
10477 posts in 3886 days
#13 posted 06-05-2017 06:46 PM
I quite like the added dust collection, it
really stops a significant amount of airborne
dust and lessens the amount of dirty debris
that hit you in the thighs when operating
a table saw.
View clin's profile
clin
973 posts in 1234 days
#14 posted 06-05-2017 07:36 PM
I have a SawStop PCS and use the guard whenever possible. I find it very easy to use and easy to put on and off.
And it is a great help with dust collection. Of course there are plenty of times I don’t use it. For example, when using a sled. But unless I can’t make the cut with it on there, it’s on there.
-- Clin
View Roger's profile
Roger
20965 posts in 3042 days
#15 posted 07-05-2017 09:12 PM
After getting my new table saw, I have found that I’ll use the guard/dust collector sometimes, but not always. It’s more in the way most of the time
