DIY drill guide
Forum topic by jtrz posted 06-04-2017 04:53 PM 1545 views 0 times favorited 13 replies Add to Favorites Watch
View jtrz's profile
jtrz
164 posts in 1412 days
06-04-2017 04:53 PM
I don’t have a drill press and I’m not ready to drop $40 or more for a read drill guide attachment/system so I am wondering if anyone has ever made a drill guide?
I am not trying to drill at an angle just a nice straight 90 degree hole. I intend to use it to drill 3/4 inch holes into
the 1.5” side of a 2×4 for a lumber rack but I suspect it will come in very handy for a lot of projects. It doesn’t need to be dead on accurate I am just looking for a simple design that will get the job done.
Any ideas or examples of ones that you have made would be greatly appreciated.
Thanks
-- Jeff | Louisville, Ky
13 replies so far
View waho6o9's profile
waho6o9
8539 posts in 2816 days
#1 posted 06-04-2017 05:01 PM
runswithscissors
2928 posts in 2264 days
#2 posted 06-05-2017 03:13 AM
Pawn shops and second hand stores sometimes have portable drill guides; some actually hold a drill (as with the wood one above) and make a drill press.
View Woodknack's profile
Woodknack
12465 posts in 2619 days
#3 posted 06-05-2017 05:54 AM
I drill through a piece of scrap with my drill press then use that as a guide.
View Gilley23's profile
Gilley23
489 posts in 621 days
#4 posted 06-05-2017 10:53 AM
View BlasterStumps's profile
BlasterStumps
1073 posts in 678 days
#5 posted 06-05-2017 12:31 PM
You can use a piece of 4×4 about 6” long. Cut a 90º V-notch in one end of it making sure it is 90º to the bottom of the 4×4. Align your bit vertically in the V. Drill until you have a good start into the wood you are drilling. Then remove the V- block and complete the hole. You can use a thinner piece of wood for small bits.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
BlasterStumps
#6 posted 06-24-2017 01:31 AM
It’s funny how sometimes things just pop up… I just found this Portalign drill guide a couple days ago. It’s a vintage Craftsman from probably around the 60’s or 70’s I’m guessing. Looks to be unused. I had the drill and a 3/8 chuck to use with it. I was planning to use my Irwin 3/4” Speedbor bit to drill some dog holes. Since the drill is not too hefty, might have to go slow.
View papadan's profile
papadan
3584 posts in 3607 days
#7 posted 06-24-2017 02:12 AM
Jeff, take a scrap of 1X , about 5 inches long. Drill a 1/4 inch hole through the center of it and drive a screw or nail into each end about 2 ” from the center hole. This is a center finder. Place it over the edge of the 2X4 with the hole over you peg mark. Drill a 1/4 ” hole in the 2X. Then go back to each 1/4” hole and drill them out to 3/4 for your pegs.
BlasterStumps
#8 posted 06-24-2017 02:36 AM
Interesting that you mention the center finding, if you allow the rods on this drill guide to extend down through the base an inch or so, it will work as a center finder. Plus it can be set to drill angled holes. It will be fun to play around with it and see how it works. It was an extravagant purchase…$3 : )
waho6o9
#9 posted 06-24-2017 03:23 AM
It looks like it’s all metal too Blaster, good one!
papadan
#10 posted 06-24-2017 08:15 PM
That’s nice Blaster, but Jeff doesn’t have one or the money to buy one, or a drill press. That’s why he asked for ideas on how to do this.
BlasterStumps
#11 posted 06-25-2017 02:27 AM
oh I know that. I even posted above giving him a really good suggestion (IMO) on another good method for drilling just using a block of wood to guide it. I wasn’t trying to rub him with this post, just thought it was interesting that I should find one of the jigs mentioned.
Mike
That s nice Blaster, but Jeff doesn t have one or the money to buy one, or a drill press. That s why he asked for ideas on how to do this.
- papadan
View Carloz's profile
Carloz
1147 posts in 830 days
#12 posted 06-28-2017 03:51 PM
- Rick M
That is the funniest post for a long time :-)
OP needs the guide because he has not drill press.
Carloz
#13 posted 06-28-2017 03:53 PM
