What do with small area of bench top delamination?
Forum topic by Dave11 posted 06-04-2017 03:29 PM 627 views 0 times favorited 14 replies Add to Favorites Watch
View Dave11's profile
Dave11
33 posts in 2474 days
06-04-2017 03:29 PM
Pic shows the end of one half of my split-top bench. Wood is SYP mostly quarter-sawn or rift sawn from larger boards. Wood was cut and glued 5 years ago, and the two halves sat on saw horses for 4-5 years, I’m ashamed to say. Just this month I finished the bench and mounted the two tops. The center area in the pic is the only one with any delamination. I noticed a tiny line in this area right after glue-up, but it didn’t become noticeable really until I mounted the top to the bench. It involves just one end, about 8 inches, of a seven foot span.
So it’s been through 4-5 years already without a big change.
I’ve been reading all the different opinions about what to do. Some say ignore it, but now that the top is actually going to be used hard, isn’t the delam likely to worsen?
Others say try to reglue, but I can’t believe I’d ever get much glue into that without prying it further apart.
Butterfly key?
Fill the seam with epoxy?
Any help appreciated.
14 replies so far
View jonah's profile
jonah
1579 posts in 3205 days
#1 posted 06-04-2017 04:04 PM
Honestly, I’d leave it alone. It’s very minor. The very most I would do is some sort of butterfly key or dutchman. I would not use epoxy because it will make flattening or resurfacing the bench harder down the line.
Dave11
#2 posted 06-04-2017 04:45 PM
But is it likely that split will worsen as the bench gets used more heavily? Pounded on, etc?
Or should I just wait and see, and if it does, cut it apart, plane it and re-glue?
I was thinking a little prevention at this point might nip it in the bud.
View waho6o9's profile
waho6o9
8100 posts in 2483 days
#3 posted 06-04-2017 04:53 PM
Saw dust and glue
or
use all thread and bolt it together
View Jeremymcon's profile
Jeremymcon
223 posts in 586 days
#4 posted 06-04-2017 05:41 PM
Never experienced this before, but I’d consider running a threaded rod through it. Or just fill it with epoxy. I don’t see why a bit of epoxy would make future resurfacing much more difficult. My planes cut right through a small epoxy edge area no problem. A Dutchman patch could work, but I feel like it’d nerd to be a pretty large one for such a thick top. Plus you’d be banging on it… I think I’d just rather not have a Dutchman patch on my workbench. Plus they do require a bit of work.
View Rich's profile (online now)
Rich
2292 posts in 496 days
#5 posted 06-04-2017 05:44 PM
It’s difficult to get an idea of the width of the opening from the photo, but I use syringes with blunt tip needles often to get glue into hard-to-reach places. There are different gauges of needles you can get. Perhaps a smaller gauge will fit in there and let you fill it with glue.
There are charts of wire gauge diameters in inches that you can use to decide which one would work.
-- No matter how much you push the envelope, it'll still be stationery.
View MrRon's profile
MrRon
4633 posts in 3150 days
#6 posted 06-04-2017 07:05 PM
I think the quick and dirty way would be to drill a 1/2 hole through all 6 lams after first boring a 1” dia. hole at both sides as a counter bore. Use all thread, a washer and hex nuts to clamp the lams tight; then plug the counter bored holes and sand smooth. The hard way would be to rip the boards down the middle, joint and re-glue.
View jerryminer's profile
jerryminer
890 posts in 1348 days
#7 posted 06-04-2017 07:16 PM
Nobody has asked this yet, so I will: How did you attach the top to the base? Did you add some stress to the joint by screwing into the top with no room for wood movement? Or with a screw right into the joint?
View jdh122's profile
jdh122
983 posts in 2724 days
#8 posted 06-04-2017 07:32 PM
Another vote for leaving it alone. I would expect it to hold up fine to normal use.
Worst case: if it starts to open up more you can then try to repair it. Even if you can get glue into the crack as things stand it’s unlikely to stick to the wood surfaces as they already have dried glue on them (unless you used hide glue – probably not). It it got worse and it was mine I’d probably rip them apart (circular saw with guide or track saw, finish with hand saw) them rejoint the two pieces and reglue.
-- Jeremy, in the Acadian forests
Dave11
#9 posted 06-04-2017 09:14 PM
Lots of interesting opinions, thanks guys. It was glued with titebond, not hide glue.
The top attaches to the base from beneath with a few lag bolts, but not very tightly, just snug. There was a line of delamination there before, it just seemed to open up a bit more when I screwed it down. But the screws go straight in, and aren’t very tight I don’t know that would have pulled the glue line apart by itself.
I’m at the point of planing the top. Maybe I’ll cover the seam with sander dust and glue, for a quick cosmetic fix, and see what it does over time. If it worsens, I’ll try a threaded rod, and if that doesn’t work well, rip it down and reglue.
Thanks.
jerryminer
#10 posted 06-04-2017 09:43 PM
The top attaches to the base from beneath with a few lag bolts…. I don t know that would have pulled the glue line apart by itself.
- Dave11
The reason I brought this up is that shrinkage of the wood, bound by lag screws, may have added stress to the joint, causing it to open a little further than before.
View Wally331's profile
Wally331
350 posts in 1931 days
#11 posted 06-04-2017 10:25 PM
I’d go with another vote for the threaded rod. A lot of old-school highschool industrial ed. workbenches have them built in. You can always plug the counterbored hole or glue a 1/4” veneer over it to hide them!
View builtinbkyn's profile
builtinbkyn
1964 posts in 847 days
#12 posted 06-04-2017 10:34 PM
Maybe best left alone. But if you think it’s going to get worse or it offends you, and since this is bolted to the base, the easiest thing to do might be to pull it off, rip it along the split which is between two boards that were probably starved for glue, and re-glue it.
-- Bill, Yo!......in Brooklyn & Steel City :)
View rwe2156's profile
rwe2156
2803 posts in 1387 days
#13 posted 06-04-2017 11:05 PM
If it were me, I would drill and dowel it so I don’t have to worry about it.
View klassenl's profile
klassenl
185 posts in 2565 days
#14 posted 06-05-2017 01:04 PM
Rip it off and reglue. It’s the only way to make it totally closed.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
