Just a thought
Forum topic by papadan posted 06-04-2017 02:02 AM 664 views 0 times favorited 18 replies Add to Favorites Watch
View papadan's profile
papadan
3584 posts in 3392 days
06-04-2017 02:02 AM
Topic tags/keywords: question resource planer sander
How about attaching a sanding belt onto the drum of a planer! Would it be too fast and just burn the wood or do you think it would work? It would be easy enough to change over my Ridgid after planning some wood to run it back through with sand paper on the drum.
18 replies so far
View BurlyBob's profile
BurlyBob
5551 posts in 2289 days
#1 posted 06-04-2017 04:19 AM
I’m thinking a planer would be way to fast and like you say burn the wood.
View Loren's profile
10476 posts in 3671 days
#2 posted 06-04-2017 04:28 AM
View Woodknack's profile
Woodknack
11774 posts in 2404 days
#3 posted 06-04-2017 04:34 AM
Mine spins at something like 8,000 rpm, seems a bit fast for sanding wood.
View steliart's profile
steliart
2697 posts in 2712 days
#4 posted 06-04-2017 04:46 AM
Don’t know, never tried it but I’m thinking that yes the speed will be a issue unless you move fast enough over it :)
-- Stelios L.A. Stavrinides: - I am not so rich to buy cheap tools, but... necessity is the mother of all inventions
View lew's profile
lew
12101 posts in 3779 days
#5 posted 06-04-2017 01:46 PM
Like the others, I think it will turn too fast.
View John's profile
John
244 posts in 1605 days
#6 posted 06-04-2017 01:54 PM
Even in that ad, there is mention of a reduction pulley. Too fast, would need to slow it down, otherwise I can’t see why it wouldn’t work.
-- I measured once, cut twice, and its still too short...
View JRsgarage's profile
JRsgarage
247 posts in 533 days
#7 posted 06-04-2017 02:03 PM
you might be able to use a electonic speed controller to adjust the speeds if universal motor.
-- Two is One, One is None
View Planeman40's profile
Planeman40
1179 posts in 2785 days
#8 posted 06-04-2017 02:16 PM
If you have a wood lathe, it makes a nice thickness sander if you make a sanding drum to turn between centers and a wedge-shaped jig bolted to the lathe bed that, moved in or out, provided a thickness adjustment.
View AlaskaGuy's profile
AlaskaGuy
4205 posts in 2333 days
#9 posted 06-04-2017 05:27 PM
@ the speed of a planer I wonder if the the sandpaper lift from the drum and explode.
That will be a lot of centrifugal force.
papadan
#10 posted 06-04-2017 05:46 PM
Thank You all for your input. I figured it would be too fast, but just wanted other opinions. It’s too late for me to invest into a real sander so I will just keep on going the way I always have. LOL
AlaskaGuy
#11 posted 06-04-2017 05:53 PM
Too late doesn’t compute.
papadan
#12 posted 06-04-2017 05:58 PM
Too late doesn t compute.
- AlaskaGuy
Yeah, it does, Aguy!
AlaskaGuy
#13 posted 06-04-2017 06:01 PM
- AlaskaGuy
- papadan
If you say so but I guess I don’t get it.
papadan
#14 posted 06-04-2017 06:15 PM
I wont be around long enough to enjoy using it or get my moneys worth out of it. LOL
AlaskaGuy
#15 posted 06-04-2017 06:25 PM
- papadan
Sorry to hear that.
