Treen mandrel
Forum topic by Sawdust2 posted 11-28-2010 04:36 PM 2627 views 0 times favorited 5 replies Add to Favorites Watch
View Sawdust2's profile
Sawdust2
1467 posts in 3995 days
11-28-2010 04:36 PM
Topic tags/keywords: question lathe
Has anyone here used Beall’s Treen Mandrel?
Likes, dislikes?
5 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3620 days
#1 posted 01-01-2011 04:51 PM
Displaying my ignorance here but what is a Treen mandrel used for?
Sawdust2
#2 posted 01-01-2011 05:08 PM
Best way to describe it is to tell you to go to www.bealltool.com and let you look.
Plus it is a plug for JR who makes good stuff.
I got one and am enjoying playing with it.
View richgreer's profile
richgreer
4541 posts in 2982 days
#3 posted 01-01-2011 05:28 PM
I have a Treen mandrel and I would be glad to comment.
If you are using the basic mandrel, which requires a 1.25” hole, it works very well. I find that it does not work as well with the optional rings to expand it to 1.5” or 2”.
You will also read about a Treen converter that allows you to use a dowel instead of the fittings to assemble the tops. IMO, the converter does not work well. It is very hard to get it tight enough to hold the wood securely.
I don’t use the fittings or the converter. I have found my own way to make the tops.
I’d recommend buying the basic unit and giving it a try. You can make some very interesting small boxes.
One more recommendation – - Don’t bother with the cork. It’s a pain to work with. In theory, it allows for expansion and contraction of the wood so you get a good fit year round. I don’t use cork any more and I still get a good fit year round. I like to hear the pop whenever I remove the lid. It confirms that I have a nice tight fit without it being too tight.
Sawdust2
#4 posted 01-01-2011 06:39 PM
I’ve made a few “boxes” but no tops yet.
I’ve looked, just quickly, locally for some of the 1/2” inserts he supplied. No joy.
I’d thought I would just thread the hole for the top and screw it on to his top maker then just jam a 1/2” dowel in the hole.
Or put a 1/2” dowel in the top, put that in the collet chuck and turn it.
It gave me an idea for another cute little item. I like the 1.07” LED lights for a buck. I bought a 27.5mm drill bit, turned a piece of maple to the right size. Drilled the hole all the way thru a nice piece of padauk or zebra wood, put it on the home made mandrel, turned it right small and epoxied the light into it. Nice improvement.
I like to use CA when finishing pens so I used that on the round boxes. LOL. They have a higher centrifugal speed than pens. CA flew all over my apron!
I hear you. I’ll probably try the cork at least once, anyway.
View panamint's profile
panamint
46 posts in 2349 days
#5 posted 09-19-2011 03:46 AM
Hey Rich I know this is a old post but was wondering if you would mind sharing the way you found to not use the inserts or adapter for the Treen tops. I can’t get the adapter to grab the lid or stopper very good.
Thanks Scott
-- https://www.facebook.com/scottswoodworks
