Help Needed Makita 2704 fence and blade
Forum topic by Aaaboq posted 06-03-2017 01:04 PM 860 views 0 times favorited 1 reply Add to Favorites Watch
View Aaaboq's profile
Aaaboq
1 post in 562 days
06-03-2017 01:04 PM
Topic tags/keywords: tablesaw blade
Hi,
i recently bought a makita 2704 table saw. i love the machine the quality build is good its rigid.
my only issue with it as you can see from the attached photos when i remove the Auxiliary fence plate that came with the saw. the fence is parallel with the blade but the table saw tape shows negative ’’-0 ’’ and another photo when i align the fence to the zero in tape. the fence is no longer touching the blade there is a gap of approximate 3 CM .
when the Auxiliary fence plate attached to the fence the tape read correct and the fence is touching the blade
can some on input on this please.
thanks.
1 reply so far
View mrg's profile
mrg
840 posts in 3203 days
#1 posted 06-03-2017 02:25 PM
With the aux fence in place you have zero. The saw is set for use with the aux fence. If you want to use the fence without the aux fence slide the fence to the blade loosen the two screws for the curser and adjust to zero. Now it is setup for using the fence without the aux fence. The difference in your reading is the thickness of the aux fence.
If you were crosscutting using your miter gauge and you wanted a length of 3 inches you would put a block of 3/4” as your stop. Set the fence to 3 3/4 to get a 3” piece and not pinch once thru the blade.
Does that make sense.?
-- mrg
