Since it isn't obvious, I'll ask!
Forum topic by Kirk posted 241 days ago 191 views 0 times favorited 4 replies Add to Favorites
View Kirk's profile
Kirk
31 posts in 541 days
241 days ago
Topic tags/keywords: question leg vice bench traditional
Greetings,
I built a workbench. And I have seen, bench leg vice, and most have a wooden screw. So I bought a 1 1/8” x 20” @ 4tpi screw for a vice, that attaches to the leg of the bench. I got the screw to run parallel to the floor and centered in the holes that I drilled.
Now, I know what you thinking, that the moving jaw will spin with the movement of the screw, it doesn’t, and everything seems good.
My question, when you tighten something, what is in place on the floor side of the vice?
I have added a picture of the vice on my projects of my workbench.
-- W. Kirk Crawford - Tularosa, New Mexico
View GaryK's profile
GaryK
8489 posts in 475 days
241 days ago
I’m not sure how they are traditionaly done, but I would use a big tenon on the table and a slot on your movable clamp.
4197 posts in 705 days
241 days ago
I saw plans for one like this recently, and the bottom just slid on a piece of 3/4” pipe to keep it aligned.
View Don Niermann  's profile
Don Niermann
134 posts in 459 days
241 days ago
I think what you are wondering about is the parallel guide. It is in the Autumn issue of woodworkingmagazine. It may be on the website in letters. IOt ia pictures as a mortised piece of wood with holes in it to put a peg in depending on the opening of the vise jaws. Christopher Schwarz said it could be at floor or 20 inches from benchtop.
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
View Eric's profile
Eric
666 posts in 270 days
241 days ago
I was going to say what Don said. Cut a mortise in the leg, near the bottom. Then attach a long-ish thin (maybe 7/8” wide by 3” high?) board to the bottom of the leg that will fit into the mortise, and that has holes drilled at intervals. Get the vise pretty close to clamping distance and slip a peg in the hole just outside the leg. When you crank the vise, that peg will keep the bottom of the leg out and increase clamping pressure up top.
Don’t know if that was clear or not, but should get you close anyway! I haven’t built mine yet, but plan to, so if there is a flaw in my explanation, feel free to correct me!
-- Eric at http://adventuresinwoodworking.com
Bookmark And Share This Page
