Ridgid planer R4330 Drive belt help
Forum topic by smw6442 posted 11-28-2010 04:51 AM 8263 views 0 times favorited 11 replies Add to Favorites Watch
View smw6442's profile
smw6442
25 posts in 3028 days
11-28-2010 04:51 AM
I have a Ridgid Planer R4330 and the belt broke and Home Depot where i bought it from says they don’t sell the belts..so i ordered a belt online. Can anyone tell me how to put the belt on..any help would be great..thanks steve
11 replies so far
View Blakep's profile
Blakep
232 posts in 3042 days
#1 posted 12-03-2010 12:32 AM
Do you have your manual for it? It should tell you in there. If you don’t have it then do a quick search online and you can probably print one off.
View Howie's profile
Howie
2656 posts in 3162 days
#2 posted 12-03-2010 12:47 AM
Go to ridgids website,I’m sure their techs can help.
-- Life is good.
View NBeener's profile
NBeener
4816 posts in 3413 days
#3 posted 12-03-2010 12:55 AM
This should get you rigiht there….
-- -- Neil
View smoke's profile
smoke
123 posts in 3261 days
#4 posted 12-10-2010 07:17 PM
I’m looking to get a ridgid planer…would you suggest it or a different one?
NBeener
#5 posted 12-10-2010 07:47 PM
I like my R4330 a lot.
Like many Ridgid tools … I think most people are pretty darned happy with them—particularly at their price point, and with the Lifetime Service Agreement.
-- -- Neil
View sptfish's profile
sptfish
68 posts in 3301 days
#6 posted 07-19-2011 06:17 AM
Steve
The manual has nothing in it regarding the replacement of the belt. As a matter of fact I can’t find any information on the net to help. It is alot of screws, and the strip very easily, but take the top off first, then the sides. That will expose the belt.
If you have found out any information, please let me know.
-- Sptfish, Naples, Florida, http://www.ckherzer1@comcast.net
View Bernard's profile
Bernard
3 posts in 2568 days
#7 posted 01-10-2012 11:20 PM
i just replaced my belt. it is involved. you remove the top cap (4 screws) crank the motor asssembly to the top exposing two hidden screws in side wall, remove those and the two at the top and remove sidewall after taking crank and repeat a cut knob off. tension adjustemnt screw is right near the motor pulley. loosen it and push motor inward while sliding belt over pulleys. it is a little tough getting the belt in between the pulley and main carriage.
View Putttn's profile
Putttn
115 posts in 2518 days
#8 posted 08-26-2013 02:19 AM
Great help to get the belt fixed. Only problem I’m having is I get 3 cap screws released and the 4th cheap cap screw rounds off and I can’t get to it now, especially since it’s recessed. If I ever get the pos cap screw out I’m going to replace all of them with something resembling metal!!!
Any suggestions?
-- Bill eastern Washington Home of beloved ZAGS
Bernard
#9 posted 08-26-2013 09:25 PM
I had the same thing happen on one of them. I used an oversized drill bit to drill the head completely off. Once removed I drilled a hole into the shaft of the screw and used an easy out to get it out of there. The tool they give you for the square heads is pretty crappy. Use a good #2 size square driver bit from your local hardware store. Especially for blade replacement or adjustment going forward. Its aluminum with soft steel screws and they bind. Best to use a anti seize compound on them when you put it back together. Hope this helps.
Putttn
#10 posted 02-22-2014 10:10 PM
Just got my Rigid 4330 apart. Where do we get belts??
Bernard
#11 posted 02-23-2014 07:21 PM
they have them at ereplacementparts.com or even e-bay.
