No-chuck lidded box
« back to Woodturning forum
Forum topic by MrUnix posted 06-02-2017 04:14 AM 888 views 0 times favorited 10 replies Add to Favorites Watch
View MrUnix's profile
MrUnix
6925 posts in 2341 days
06-02-2017 04:14 AM
Topic tags/keywords: lidded-box woodturning tutorial no-chuck
I’ve had a few people ask me about using threaded glue blocks for turning stuff like lidded boxes, so thought I’d show one method of doing it. Here is a basic 5 step tutorial showing how I made a couple from some spalted oak.
Obviously, the first thing you need to do is make up a threaded glue block (as described in the woodturning on the cheap thread), and then prep the blank:
Once prepared, the rest is easy :)
The blank above was enough to make two small lidded boxes. They are approx. 3.5” in diameter. The short box is roughly 2” high, and the larger one is about 3.5” high. Both were finished with oil based poly.
Of course, this is by no means the only way to go about it… there are plenty of ways to do it and lots of variations even between similar processes. Please post yours… the more alternatives people have, the better.
10 replies so far
View hairy's profile
hairy
2764 posts in 3675 days
#1 posted 06-02-2017 11:38 AM
Good on ya, mate!
-- My reality check bounced...
View Jim Jakosh's profile
Jim Jakosh
21288 posts in 3248 days
#2 posted 06-02-2017 12:05 PM
Nice process!!
View Nubsnstubs's profile
Nubsnstubs
1403 posts in 1872 days
#3 posted 06-02-2017 02:57 PM
Good job, Chuckless….. hehehe Seriously, Brad, you did good. The wood is as good looking as it gets.. I don’t know how making a box following this tutorial couldn’t get any more simple than that. Thanks for posting it…...... Jerry (in Tucson)
View KelleyCrafts's profile
KelleyCrafts
3173 posts in 882 days
#4 posted 06-02-2017 03:07 PM
More than one in a single mounting. I like it.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
MrUnix
#5 posted 06-03-2017 07:40 PM
Shhhhhh!! I actually bought a Barracuda chuck a while back, so that title is not entirely fitting any more :)
Using the chuck works just as well… however for some things, there is an advantage to using the threaded glue blocks. For example, you can mount/unmount the piece as many times as you need without worrying about alignment problems or the piece not running true when re-mounted. Here are a couple of boxes I made out of cedar that incorporated an epoxy inlay:
To make them, you need to mount/re-mount them a few times between steps, so you can do the epoxy work (notice that the epoxy does not extend all the way to the inside of the box). Since the glue block stays on the piece until it’s completely done, and then parted off, it will always turn true when re-mounted.
BTW: The two bowls above were also made using threaded glue blocks. And they were made from more spalted oak… I’m up to my eyeballs in the stuff ;-O
Nubsnstubs
#6 posted 06-03-2017 09:29 PM
To make them, you need to mount/re-mount them a few times between steps, so you can do the epoxy work (notice that the epoxy does not extend all the way to the inside of the box). Since the glue block stays on the piece until it s completely done, and then parted off, it will always turn true when re-mounted.
BTW: The two bowls above were also made using threaded glue blocks. And they were made from more spalted oak… I m up to my eyeballs in the stuff ;-O
- MrUnix
Oh, Brad, you finally broke down and got one? Did Rick or myself finally shame you into getting one? Lol..
Ok, now that that’s done, are you going to be doing larger stuff? If so, I have a deal for you that you can’t refuse. PM me and i let you know what it is…...... Jerry (in Tucson)
MrUnix
#7 posted 06-04-2017 05:40 AM
- Nubsnstubs
Well, that may have been a small part pushing me in that direction :)
Actually, my old Delta has an odd-ball spindle size, which really narrowed down my selections… and I didn’t want to spend 4-5 times (or more) what I paid for the lathe just to get an odd-ball chuck. Once I got the Powermatic, it was a little easier. I still prefer to use threaded blocks on the Delta though, and I got another thread tap so I can make them (and other stuff) for the Powermatic as well.
View helluvawreck's profile
helluvawreck
32083 posts in 3009 days
#8 posted 06-04-2017 05:04 PM
This is an interesting technique. However, I would still prefer to use a chuck because I think it would be more foolproof and safer. But I can understand your situation and your reasoning for using this method.
helluvawreck aka Charles
View Woodknack's profile
Woodknack
12369 posts in 2522 days
#9 posted 06-05-2017 05:53 AM
- MrUnix
MmmmmHmmm, the lure was too strong.
Nubsnstubs
#10 posted 06-05-2017 02:04 PM
Yep, Rick, when we can coax Brad into getting something that he says isn’t really necessary, the force is strong within us. heheeh…....... Jerry (in Tucson)
