Cabinet door repair technique suggestions needed
Forum topic by Andybb posted 06-02-2017 03:00 AM 2548 views 0 times favorited 6 replies Add to Favorites Watch
View Andybb's profile
Andybb
1060 posts in 653 days
06-02-2017 03:00 AM
Have a friend who has asked me to repair his below the sink kitchen cabinet door. I’m thinking I need to square the end off with a router or router plane and scarf in a new piece of oak, then cut the mortise for the hinge, plane it down and try to match the stain? Not sure if he has the piece that broke off. If he does, since glue is stronger than the wood do you think that would hold or should I square off and scarf?
-- Andy - Seattle USA
woodbutcherbynight
5216 posts in 2459 days
#1 posted 06-02-2017 04:26 AM
If he has piece, glue and slightly scuff surface. If not square off and put in a new piece. I would take some scraps of whatever you use to insert into it and play with some stains to find the best match. Being it is inside the door not such a bother, but still aim for the fishes head.
View shipwright's profile
shipwright
8000 posts in 2848 days
#2 posted 06-02-2017 05:25 AM
There is no better fit than a clean break. If he has the piece just glue it back. It already matches in patina.
I would dry fit it by gently moving it looking for that perfect spot. If a splinter is preventing the seating, just remove it and the piece should register and glue back seamlessly.
If the piece is gone, that’s really too. Yo will need to plane a flat and glue a new piece.
Andybb
#3 posted 06-02-2017 07:44 AM
Thanks. He doesn’t have the piece I found out. He dropped off the door. It’s much smaller than I thought. Only about a 2 inch long piece.
Andybb
#4 posted 06-03-2017 05:57 AM
Thanks for the advice. Planed it flat. Probably should have found a scrap of oak but it’s on the inside of a lower cabinet door. Very easy fix.
View GR8HUNTER's profile
GR8HUNTER
4092 posts in 762 days
#5 posted 06-03-2017 01:28 PM
looks nice …GREAT JOB :<))
View waho6o9's profile
waho6o9
8237 posts in 2627 days
#6 posted 06-03-2017 01:35 PM
Blends in nicely Andy, good job!
