UNflat MDF...Can it be fixed?
Forum topic by ChrisCarr posted 11-27-2010 07:41 AM 944 views 0 times favorited 3 replies Add to Favorites Watch
View ChrisCarr's profile
ChrisCarr
196 posts in 2895 days
11-27-2010 07:41 AM
I have a 2×2 ft. piece of mdf left over from another project and want to use it on something. The problem is for what I need to use it for it MUST be dead flat and currently it is cupped about 1/8 to 1/16 in the center of it. Is there a way to make it flat?
I can’t hand plane it because I lack the skills (i just can’t get good at using a hand plane to flatten). I have a handheld portable power planer however.
3 replies so far
View mfike's profile
mfike
100 posts in 3662 days
#1 posted 11-27-2010 07:50 AM
What are you gonna use it for? I wouldn’t plane it. Can you attach it to a hardwood frame and use it ?
ChrisCarr
#2 posted 11-27-2010 07:55 AM
I was going to use it for a Drill press table.
I has going to glue another piece over it but just like paint…Whatever is on top is only as good as what is beneath it. The first would bow the second. I was also going to Glue some solid wood around the edges.
mfike
#3 posted 11-27-2010 08:09 AM
Well you can glue straight hardwood edging about 1.5” wide to the edges which should keep it flat, but as cheap as mdf is I would just buy a sheet. Most places have bins where you can buy quarter sheets if you don’t want/need a whole sheet.
