Wood Expansion question
Forum topic by twobyfour16 posted 907 days ago 1282 views 0 times favorited 6 replies Add to Favorites Watch
View twobyfour16's profile (online now)
twobyfour16
40 posts in 1654 days
907 days ago
Topic tags/keywords: bench workbench question joining wood expansion seasonal
So, I’m slowly working on building my workbench. So far, I have the top laminated up, along with some other components for the trestle base. I laminated my benchtop with 62 pieces of hardwood that are about 3/8” thick and 3 1/4” wide. The top is now about 24” wide & 7 ft long. I plan on putting a skirt around it, like most folks do, as well as a face & twin screw end vise. So here’s the question: With the top laminated from so many pieces, am I going to have more or less seasonal expansion across the width of the bench? I’m going to attach the end skirts with a tongue on the benchtop & groove in the end skirt. Do you think I can get away with gluing it the full width, or is that asking for trouble? I want to avoid using barrel bolts & make the entire bench out of wood.
-- Allan, Portland, OR
View GaryL's profile
GaryL
988 posts in 999 days
#1 posted 907 days ago
Your still going to have the same amount of expansion and contraction as if it were a solid piece of hardwood. It will be more structural stable though because of the multiple laminations. The end skirts will still need to be designed with movement in mind.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View RalphBarker's profile
RalphBarker
80 posts in 938 days
#2 posted 907 days ago
I agree with Gary. You likely won’t have a lot of expansion across the end of the bench, but you’ll still have some that needs to be accommodated.
View Bill Davis's profile
Bill Davis
217 posts in 2093 days
#3 posted 907 days ago
Wood is hygroscopic which means it take up moisture and give up moisture as the %RH increases and decreased. In doing so the wood will expand and contract and even a good finish will not prevent that, only slow it down. Wood expands roughly twice as much tangential to the growth rings as it does perpendicular to them and a negligible amount along its length. With a lamination the grain directions are mixed so that will mitigate swelling and shrinking but not eliminate it. How much expansion/contraction occurs is pretty hard to estimate so take some moderate precautions in fastening the skirt especially across the end grain.
Beautiful piece. Will make an envious workbench.
twobyfour16
#4 posted 907 days ago
Thanks guys. I appreciate the input. I think I will glue the end skirts on one side, and fasten the other side with a barrel bolt with an elongated hole to allow for expansion. Better safe than sorry. The top has been in my garage for a couple months now & I regret not measuring the width exactly – it would have been a good experiment to see how much expansion I get. It was hot & relatively dry when I finished laminating the top in july or august, and is cold & wet now. Live & learn….
Thanks again.
View wseand's profile
wseand
1549 posts in 1211 days
#5 posted 907 days ago
GO DUCKS…....!!!!! That is all. he he.
-- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy
View Lumber2Sawdust's profile
Lumber2Sawdust
112 posts in 1034 days
#6 posted 907 days ago
I agree with others here. You will have to allow for movement. I recently completed a similar bench. To allow it to move, I glued the first 3-4 inches at the front of the apron, then pinned the tongue at a few places along the length, with elongated holes to allow it to move. I used walnut dowels for the pegs to highlight the contrast. It worked well with some of the other bits of the bench.
EDIT: You can see the pegs in my bench top in my project, posted here.
