Using wet/dry sandpaper
Forum topic by MagicalMichael posted 05-31-2017 01:46 PM 684 views 0 times favorited 10 replies Add to Favorites Watch
View MagicalMichael's profile
101 posts in 448 days
05-31-2017 01:46 PM
What do people use to wet an oil finish when sanding between coats?
-- michael
10 replies so far
4906 posts in 2425 days
#1 posted 05-31-2017 02:14 PM
water….preferably distilled and in a small spray bottle.
View papadan's profile
3584 posts in 3300 days
#2 posted 05-31-2017 03:03 PM
View Rich's profile
2468 posts in 521 days
#3 posted 05-31-2017 03:18 PM
I set this thread to “Watch” so I could learn from the replies. I have to say that I did not expect water to be recommended for wet sanding oil finishes between coats. My guess would have been to use some of the oil finish itself to create a slurry. Purely uneducated guess though.
Looking forward to see how this plays out.
-- No matter how much you push the envelope, it'll still be stationery.
View MrRon's profile
4667 posts in 3175 days
#4 posted 05-31-2017 04:30 PM
When I used to use Danish oil, I would use the same oil for wet/dry paper. I too would assume the same for any oil as Rich Taylor stated. To my way of thinking, “water and oil don’t mix”. Correct me if I’m wrong.
View Ron Aylor's profile (online now)
Ron Aylor
2307 posts in 579 days
#5 posted 05-31-2017 04:42 PM
Actually, I dry sand an oil finish between coats, with “used” 400 grit paper … then wipe up the dust with turpentine.
-- Ron in Lilburn, Georgia.  Knowing how to use a tool is more important than the tool in and of itself.
View Jack Lewis's profile
Jack Lewis
255 posts in 1010 days
#6 posted 05-31-2017 05:11 PM
I recently started using multi grit grades of non-woven pads in between coats of rattle can lacquer. I have used it dry with good results.
-- "Now we are getting no where, thanks to me"
View jdh122's profile
992 posts in 2749 days
#7 posted 05-31-2017 05:37 PM
I wonder if people are talking about two different things here – oil finishes (BLO, tung oil, Tried and True) and oil-based finishes? I wouldn’t spray water on top of tung oil to sand it. With these types of drying oil finish you don’t so much sand between coats as apply a coat while sanding.
-- Jeremy, in the Acadian forests
#8 posted 05-31-2017 07:52 PM
I wouldn’t spray water on a tung oil finish either…..I had assumed it was varnish that Michael was asking about. If it’s an oil finish I don’t sand between coats. But I have sanded oil finishes to make a slurry to fill the pores, for that I just use the same oil as the finish.
View Ger21's profile
1074 posts in 3063 days
#9 posted 06-02-2017 10:39 PM
2693 posts in 1957 days
#10 posted 06-05-2017 03:25 AM
Ben Matte, which is Daly’s Danish rubbed oil finish, is supposed to be wet sanded on the first coat. 400 to 600 grit we-or-dry. Drives the finings into the pores of the wood. They say that sanding should not be necessary for subsequent coats.
