Hexagonal nuts in a round hole
Forum topic by unclearthur posted 05-31-2017 03:06 AM 1172 views 0 times favorited 9 replies Add to Favorites Watch
View unclearthur's profile
unclearthur
180 posts in 1810 days
05-31-2017 03:06 AM
I was trying to make a fidget spinner for my daughter, and was going to use 3 hexagonal nuts as the peripheral weights. I thought I could drill holes slightly smaller than the nuts, and file the edges a little to make the nuts fit.
Due to a mixture of poor skills and lack of patience this was a disaster. Very time consuming and very sloppy results.
Any suggestions how to make a tight fitting hexagonal hole for nuts? Nuts are about 3/4” OD and 1/2” thick.
Thanks.
9 replies so far
View jonah's profile
jonah
1721 posts in 3321 days
#1 posted 05-31-2017 03:40 AM
Wouldn’t it be easier to just use something round instead, like some washers?
MrUnix
6762 posts in 2221 days
#2 posted 05-31-2017 04:06 AM
Several ways to drill a hexagonal hole… google is your friend.
Here is one such example.
unclearthur
#3 posted 05-31-2017 04:43 AM
Wouldn t it be easier to just use something round instead, like some washers?
- jonah
Definitely easier, but the nuts looked better.
unclearthur
#4 posted 05-31-2017 04:45 AM
- MrUnix
That makes sense. Thanks for the link. Will be a challenge being so precise on the drill press with so many holes, but lots better than monkeying with a file., at least for me.
View bandit571's profile
bandit571
20211 posts in 2706 days
#5 posted 05-31-2017 04:45 AM
Maybe use square nuts. Easier to chop a square hole
View Carloz's profile
Carloz
1147 posts in 614 days
#6 posted 05-31-2017 05:28 AM
Widen the holes you already have, insert the nuts and fill the gaps with epoxy
View Woodknack's profile
Woodknack
11771 posts in 2403 days
#7 posted 05-31-2017 06:48 AM
View ClammyBallz's profile
ClammyBallz
435 posts in 1159 days
#8 posted 05-31-2017 05:48 PM
Roo Glue works well for bonding metal to wood. I used it to hold some nuts on a saddle fence I made.
View HokieKen's profile
HokieKen
5199 posts in 1161 days
#9 posted 05-31-2017 05:57 PM
Drill your hole the same size as the width across the flat of the nuts. Heat the nuts up with a torch, get them good and hot. Not glowing but hot. Now insert and tap lightly with a hammer. The nut should “burn” a hex shaped hole. You may have to do it 2 or 3 times to get to full depth.
I’ve never done it with a nut or with anything as big as 3/4” but I’ve done this to insert wide tangs and square and hex shaped shanks into tool handles. It’s not hard and always gives a perfect fit. Usually don’t even need epoxy.
-- Kenny, SW VA, Go Hokies!!!
