Picnic table
Forum topic by MrRon posted 05-30-2017 07:16 PM 448 views 0 times favorited 3 replies Add to Favorites Watch
View MrRon's profile
MrRon
4797 posts in 3271 days
05-30-2017 07:16 PM
I plan to build a picnic table, 30” wide x 96” long. I want to use decking that is made with recycled plastic (Trex or equal). I will need to tie the boards together with battens. Anyone have any experience with this type of decking? such as; what material to use for the battens? What screws to use that will hold in this plastic material? I figured this material would stand up well outdoors unlike solid wood. The material I’m looking at is 5.4” wide and 1” thick, called “Choicedek” composite deck boards.
3 replies so far
MrRon
#1 posted 06-03-2017 01:02 AM
I plan to build a picnic table, 30” wide x 96” long. I want to use decking that is made with recycled plastic (Trex or equal). I will need to tie the boards together with battens. Anyone have any experience with this type of decking? such as; what material to use for the battens? What screws to use that will hold in this plastic material? I figured this material would stand up well outdoors unlike solid wood. The material I m looking at is 5.4” wide and 1” thick, called “Choicedek” composite deck boards.
- MrRon
This is a re-post as no one has yet replied.
View jerryminer's profile
jerryminer
928 posts in 1469 days
#2 posted 06-03-2017 02:51 AM
Hi MrRon—I’ve built several picnic tables, but never out of composite material. What I know about composite decking is that it sags. You will need extra support—more than just battens—to prevent the sag. See what the decking mfr. recommends—sometimes its 12” joist spacing, so plan the sub-structure accordingly.
Screws: any of the screws made for composite decking should be fine. Or, you can design a system that uses hidden fasteners, like screws from underneath. If you want it to last forever, use stainless steel
MrRon
#3 posted 06-03-2017 08:58 PM
Thank you Jerry. I will add more battens and use SS screws.
