How do you make wooden wheels?
Forum topic by HuntleyBill posted 11-25-2010 07:22 PM 7498 views 0 times favorited 9 replies Add to Favorites Watch
View HuntleyBill's profile
HuntleyBill
103 posts in 2996 days
11-25-2010 07:22 PM
Happy Thanksgiving LJ’ers:
I’m looking to make some wooden wheels for some toys for the kids. Some wheels will be 4 inches and some will be about 3 inches. I have made a few on my lathe but they didn’t turn out as well as I think they should ( no pun intended)!
My lathe is a home made lathe I picked up and it doesn’t have a lot of fancy features…in fact id doesn’t have any fancy features. Basically has t centers and thats it. Anyway, I thought maybe if I used my router to to recess the insides hence making an outer wheel and an inner hub. I then thought I’d drill some holes in that recess to simulate spokes…sort of.
My questions are: Can I do it with a router?
Has anyone already made a jig to accomplish this?
Is there a better way to do it (besides buying the wheels)?
If so, please explain.
Thank you all for your help
Bill
-- If you think you can, or think you can't...your right!
9 replies so far
View Luke's profile
Luke
545 posts in 3199 days
#1 posted 11-25-2010 07:36 PM
How big are you wanting to make the wheels?
You could use a router with a circle cutting jig that you could make yourself but not if they will be really small. I believe it’s called a router trammel. Sounds like a good idea drilling out the middle, it would kind of have the look of billet truck wheels that you see on some pickups?
-- LAS, http://www.abettersign.com
View richgreer's profile
richgreer
4541 posts in 2980 days
#2 posted 11-25-2010 09:15 PM
Have you considered a circle cutter like this?
http://www.rockler.com/product.cfm?page=2393&filter=circle%20cutter
View Gene Howe's profile
Gene Howe
10126 posts in 3334 days
#3 posted 11-25-2010 09:44 PM
Just use a Forstner for the recess, then cut the wheel out with a hole saw.
Drill press necessary!
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3491 days
#4 posted 11-25-2010 09:54 PM
The lathe will make the very best result no question I have made many you need to make them individually with an expanding mandrel or block wiith between centres making up to four or more at a time this way it’s easier to visualize what the sizes are like but for facing cuts/finish with some kind of expanding jaw mandrel set up don’t cut into end grain they won’t be strong you must cut the wood as if for a bowl turning session have fun Alistair
View MrsN's profile
MrsN
983 posts in 3431 days
#5 posted 11-26-2010 12:22 AM
I buy most of my wheels, they are a lot of work to get right and I would rather spend my efforts elsewhere.
3 and 4 inch wheels are bigger then most of the toy wheels that I use, With the proper jigs you may be able to safely use a router. I would use a hole saw like Gene mentioned.
Good Luck
mrsn
View helluvawreck's profile
helluvawreck
30147 posts in 2772 days
#6 posted 11-26-2010 12:55 AM
I don’t think there would be anything at all wrong with making wheels on a lathe. As a matter of fact you could gang them up to machine the outside if you were set up to do it. You might have to make a fixture to do it. Then you could chuck ‘em up and machine the inside or make a fixture and do it on a drill press. I’m not speaking from experience on a wood lathe but I’ve done similar things with steel on a metal lathe. I’m just thinking out loud here – sometimes you get in trouble when you think out loud – somebody might hear you. :)
View bobdurnell's profile
bobdurnell
315 posts in 3803 days
#7 posted 11-26-2010 02:28 AM
HuntleyBill—I have made many wheels for all sorts of vehicles without using and lathe or router. Just the desired size hole saw. I remove the wheel from the hole saw and then I make a mandrel using another wheel a little smaller in diameter and then gluing a 1/4” dowel thru it some goes thru to allow the wheel to spin and the other is for the hand to hold. Now I use a horizontal drum sander or a 6×48 vertilcle belt sander and let the wheel spin as you touch the belt or drum and the profile of the wheel can be established accordingly. I hope this helps. bob
-- bobdurnell, Santa Ana California.
View twokidsnosleep's profile
twokidsnosleep
1106 posts in 2879 days
#8 posted 11-26-2010 03:04 AM
My way:
Easy and consistent; the center hole is always dead on
-- Scott "Some days you are the big dog, some days you are the fire hydrant"
View RalphBarker's profile
RalphBarker
80 posts in 2675 days
#9 posted 11-26-2010 08:09 PM
Another vote for a (good) hole saw of the desired diameter – on a drill press. You can glue the “tire” board to a sub-board with craft paper in between to avoid the wheels staying in the hole saw. Just set the depth short of drilling through the substrat.
