Accordian style hinging
« back to Joinery forum
Forum topic by Rob posted 05-30-2017 05:52 PM 722 views 0 times favorited 11 replies Add to Favorites Watch
View Rob's profile
Rob
317 posts in 3159 days
05-30-2017 05:52 PM
Hopefully someone here can help me. I need to make a wind breaker to go around a small camping grill to put up when the wind isn’t cooperating and causes the two burners to go out. I’m going to make it an accordion style out of luan plywood or some other thin material and need to hinge the pieces together so it can be folded up for easy quick storage. It’s not going to be fancy. Just functional that allows access to the grill controls. Each section will be 12”X12”. Any ideas on how to attach these pieces together so they lay flat on each other? I thought about cloth tape for book binding but I don’t know if that stuff will stick to wood.
11 replies so far
View Rob's profile
Rob
#1 posted 05-31-2017 03:34 PM
I guess no one has any ideas
View johnstoneb's profile
johnstoneb
3033 posts in 2345 days
#2 posted 05-31-2017 04:06 PM
Piano hinge
-- Bruce, Boise, ID
View Loren's profile
10477 posts in 3820 days
#3 posted 05-31-2017 04:28 PM
It seems to me most any small flat hinges
will work. You could also use duct tape
or glue leather to the wood as a hinge.
View Nubsnstubs's profile
Nubsnstubs
1414 posts in 1903 days
#4 posted 05-31-2017 04:32 PM
Any 2” butt hinge. Just make sure you hinge each set of panels properly. A piano hinge is just a real long butt hinge. It will work to, but you might have to cut it to fit your panels unless you can find them in the size you need. ........... Jerry (in Tucson)
View HokieKen's profile
HokieKen
6594 posts in 1311 days
#5 posted 05-31-2017 05:03 PM
I’d go with piano hinge too. They’re cheap and can be easily cut to the desired size. If you need it to lay perfectly flat for some reason, you’ll have to mortise the hinge in. But even without doing that, it’ll lay pretty darned flat.
-- Kenny, SW VA, Go Hokies!!!
View Rob's profile
Rob
#6 posted 06-01-2017 11:22 AM
Thanks for your input everyone
View Jim Jakosh's profile
Jim Jakosh
21514 posts in 3278 days
#7 posted 06-01-2017 11:33 AM
I’d use 3 piano hinges. Two going one way and the other the opposite so it folds up.
Jim
runswithscissors
2869 posts in 2198 days
#8 posted 06-03-2017 04:22 AM
I made one of those out of sheet aluminum. I bent tabs on the edges that folded over steel rods, about coat hanger gauge (thus forming the hinges; the rods had to be bent at the ends to prevent them from dropping out.) Also crimped the remaining edges all around for stiffness. You could fold the panels either way. Only downside was that it needed bracing in strong winds. I may actually still have that around somewhere, after all these years.
I believe Coleman made (or still makes) them. Though I understand your wanting to make one out of wood, I’m doubtful it is the best material for the job. But, good luck with whatever you try.
View Rob's profile
Rob
#9 posted 06-03-2017 11:53 AM
I tried the piano hinge idea. That didn’t work. Screw holes were the same location on both sides of the hinge so it wouldn’t lay close to flat. Finally gave up when I saw sheet metal wind shields on Amazon for $8.00 Heck, I had more money in the hinge I bought than that!
View splintergroup's profile
splintergroup
2341 posts in 1395 days
#10 posted 06-03-2017 01:04 PM
There are “special” spring loaded, double jointed hinges like the type used on swinging doors that would allow you to fold it up flat and still position it into your curve, but you found a solution that is probably 10x cheaper 8^)
View Just_Iain's profile
Just_Iain
291 posts in 589 days
#11 posted 06-04-2017 11:41 AM
Having used aluminum stove screens for years, I’d suggest the aluminum. Wood had the advantage of weight to keep it stable (hence why aluminum screens tend to have overly long hinge pins to push into ground) but will discolour over time due to heat. Plus consider that either could fall into the fire over time which means the wooden one could go up in smoke literally.
-- For those about to die, remember your bicycle helmet!
