| Forum topic by nmkidd | posted 909 days ago | 1434 views | 2 times favorited | 10 replies | ![]() |
909 days ago |
OK…....I’m perplexed!!!!.........whilst in the porcelain reading room….....perusing catalogs….........I find there are portable table saws…......contractor saws…..........cabinet saws…............and …........... hybrid saws!!! What the heck is a hybrid saw????? Someone please enlighten me thx Everyone have a Great Thanksgiving!!!! -- Doug, New Mexico.......the only stupid question is one that is never asked!........don't fix it, if it ain't broke! |
10 replies so far
#1 posted 909 days ago |
Portable saws have small aluminum tables and universal motors. Universal motors are lighter than inductions motors of the same power, but they are much, much louder. The cheap portable saws are useless for woodworking as far as I’m concerned. They might get the job done, but they just won’t have the repeatable precision of a full size saw. Their claims of horsepower are often over-rated. Contractors saws were considered to be portable many years ago. The motor hangs off the back of the saw and is easily removed to lighten the load if you need to move it in and out of a truck. Not fun but doable. Contractors saws have cast iron tops, and may have cast iron wings (the left and right sides of a top). More often they have stamped steel wings. They are usually 1-1/2hp which will get the job done, but can be a bit underpowered for ripping thick pieces of hardwoods. They are the same size as cabinet saws but much lighter. On table saws weight is a good thing. It stops any vibrations which can create inaccuracy. Some contractors saws come with fences that aren’t much better than those on portable saws. Cheaper fences lock into place at the front and back of the saw, this often makes it hard to set the fence parallel to the blade every time. Nicer fences are built much beefier so that they can lock along only the front rail of the saw and have the strength not to deflect at the back of the saw when under normal pressure. Cabinet saws have the motor inside the cabinet and have full cast iron tops (typically). The trunnions (holds the motor and arbor in place, allows the saw blade to tilt) and the arbor (the shat the blade bolts onto) are much heavier than on contractors saws resulting in higher quality cuts. Some older cabinet saws have fences that lock in front and back, but any new saw will have a good fence that locks only in front. Cabinet saws start at 3hp motors which require you to have a 220v circuit for the motor. If you can afford it, a cabinet saw is the way to go. Hybrid saws combine contractors saws and cabinet saws. They use the smaller motor of a contractor saw, so you can run it on 110v, they are usually 1-1/2 to 2 hp. The motor is also mounted inside the cabinet of the saw. A closed cabinet helps a lot with dust collection. Hybrid saws are a great option if you want some of the features of a cabinet saw without needing to have a dedicated 220v circuit put in your shop. |
#2 posted 909 days ago |
Bench top saw (on legstand): Portable jobsite saw (on legstand): Conventional contractor saw (front & rear view): Hybrid saw (front & rear view): Industrial cabinet saw: -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#3 posted 909 days ago |
ask thanks guys -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#4 posted 906 days ago |
Thanks to all for their inputs!!! -- Doug, New Mexico.......the only stupid question is one that is never asked!........don't fix it, if it ain't broke! |
#5 posted 889 days ago |
jmichaeldesign says that jobsite saws are useless for woodworking. OK, that may be the case for some kinds of work, especially those involving precision repeatable high quality cuts. However, in the old, pre-electric days fine woodworking was done by individuals who did not use power tools at all. One can only imagine how those guys would have loved to be able to use a jobsite saw for some of their work. Yes, a superb cabinet saw may allow the user to do some very nice things. However, I think that hobby enthusiasts on a budget or with little in the way of large-shop space can get away with using some kind of bench-top or folding jobsite saw for some pretty good results, particularly if they have other tools on hand (jointer, planer, band saw, benchtop sander, etc.) that will let them refine their initial table-saw cuts to a point of decent precision. Also, some enthusiasts (those who like to do work with band saws or scroll saws) may only care to make fairly small items, and for that a small table saw might work just fine for the initial cuts. Some woodworkers have a bad habit of flaunting their collection of super-duper tools that are located in a spacious shop or basement. Fine. Enjoy the tools. However, the bottom line is the quality of work produced within a certain project category, and some guys here almost certainly have produced some very fine works with low-cost tools, including low-cost table saws. |
#6 posted 889 days ago |
I do quite well with a contractor saw, I had a bench type saw and it had a hard time with 3/4 cherry flooring – burned out the motor – twice, blade is like new. The contractor saw that I bought after the second motor died is a Rigid, with cast iron wings. Wish I had the Beysmeyer fence option but I don’t. The additional weight of the cast iron wings makes a serious improvement. Setting and adjusting took time but I have been pleased. One more thing, I have found that I also enjoy using my handsaws, now that I figured out how to sharpen them – repeatedly. For some jobs, like my floor that I put in and cutting larger sheet stock, I couldn’t have done it without a clean and smooth cut, and the Rigid has performed. -- David in Damascus, MD |
#7 posted 889 days ago |
The way the motor hangs off the back of a contractor’s saw puts The hybrid saws have the motor hanging beneath the blade, so The cabinet saws usually are pretty similar to the hybrid saws but |
#8 posted 889 days ago |
Charlie – I’m sure with good technique you can get good results from a SCMS, but I don’t see how they can be more accurate than a good TS. The way the whole mechanism cantilevers from a pivot point makes them very prone to far more play than a TS….I’d bet they can move upwards of an 1/8” pretty easily. My CMS doesn’t even have the sliding feature and it’s not as accurate as my TS. My TS has a huge cast iron swing arm that the arbor is mounted too and spins with very limited runout….a good miter gauge helps me dial in precise angles and helps with repeatability of 90° cuts. The screaming universal motors on the CMS/SCMS alone are enough to prompt me to turn to be trusty quiet TS first…I’ll only use my CMS for really long pieces that the TS doesn’t handle well. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#9 posted 889 days ago |
In the cabinet shop I worked in we crosscut almost all of our parts on the table saw. With a stop block on the fence, and a good crosscut sled it provides better repeatability than a miter saw. |
#10 posted 888 days ago |
About the only thing I use the miter saw for are the compound cuts for crown molding and I am having second thoughts on that. If I am not doing the cut by hand, the tablesaw, then bandsaw wins. If I have time, I will make a jig for the tablesaw for crown moldings. -- David in Damascus, MD |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
