Disappointed in Freud Glue Line Rip
Forum topic by Woodknack posted 05-30-2017 03:47 AM 4679 views 2 times favorited 96 replies Add to Favorites Watch
View Woodknack's profile
Woodknack
12399 posts in 2554 days
05-30-2017 03:47 AM
Topic tags/keywords: lm74r010 freud glue line
LM74R010 Glue Line Ripping Circular Saw Ripping Saw Blade 10” x 5/8” Bore x 30 Tooth
This Freud blade’s specially designed triple-chip tooth design produces extremely smooth, true surfaces for gluing and finish work. There is no need for sanding or jointing after the cut.
Used it for the first time today and I’m unhappy with the cut quality. It is far from smooth or glue ready. I’m getting crosshatching, scalloping, and rough edges. I will be returning this blade and trying something else. Also have a Freud Fusion that crosscuts glass smooth and rips well enough for gluing but I bought this blade on sale to take the brunt of ripping duty and to make flat bottom cuts.
I took pictures but it’s hard to see. White oak, but I tried maple and got the same result.
96 replies so far
View Loren's profile
10477 posts in 3822 days
#1 posted 05-30-2017 04:16 AM
Try a blade stabilizer.
I used a Forrest blade reputed to rip glue
lines in the past and it performed best
using stabilizers.
In professional work, tolerances for glue
lines vary. A jointed line is the finest
but honestly glue does fill gaps to greater
or lesser extent.
You may want to try accessories like
Board Buddies as well as stabilizers in
pursuit of better glue line rips.
View Rich's profile
Rich
3757 posts in 763 days
#2 posted 05-30-2017 04:41 AM
Agree with Loren. I mentioned it in another post on some thread or another, but I have always used my Forrest stabilizer with great results, regardless of the brand of blade. The reality set in when I had to remove it to get a greater blade height for a thick board crosscut. I left it off out of laziness until I realized my zero kerf slot in my crosscut sled was widened — and not evenly. They really do work. BTW, tossed the sled.
View DirtyMike's profile
DirtyMike
637 posts in 1076 days
#3 posted 05-30-2017 04:47 AM
Rick, I would also expect better rips than that from a glue line blade. Have you hit it with a dial indicator yet? I have bought 2 Frued blades this year that i have already returned. one had a wonky arbor hole. the other (diablo) was made in china not italy as advertised and it looked terrible.
View bruc101's profile
bruc101
1255 posts in 3716 days
#4 posted 05-30-2017 05:30 AM
I’ve been using the Frued Glue Line rip blade since it was first introduced. I’ve never had any problems with it and use it on a daily basis.It’s my go to blade for just about everything other than plywood and solid surface material.
Everyone woodworker I personally know also uses the blade without any issues. I always keep a new spare one ready to go.
-- Bruce Free Plans http://plans.sawmillvalley.org
View pintodeluxe's profile
pintodeluxe
5783 posts in 2987 days
#5 posted 05-30-2017 05:51 AM
You had good luck with the fusion blade, so that tells me your TS setup and technique are sound.
I do wonder if the white oak was moving or releasing tension on you. Try some different lumber before you give up on it.
I use the LU86 40 tooth combination blade with good results. I mill white oak more than any other wood with it. Works great.
Woodknack
#6 posted 05-30-2017 06:59 AM
re: stabilizers – I’ve never needed stabilizers before. I currently own 5 Freud blades and a few other brands. Maybe it’s the saw but I’m going to try another brand of blade first and see how it goes. My satisfaction with Freud has been waning.
- DirtyMike
Not yet. I’m in the middle of a new vanity for the bath and didn’t want to stop to fool around with blades.
- pintodeluxe
I cut some red maple that’s been in the shop for 10 years, same result.
View Redoak49's profile
Redoak49
3596 posts in 2162 days
#7 posted 05-30-2017 10:49 AM
I am surprised at your result. I have that blade and it works fine for me.
View HokieKen's profile
HokieKen
6605 posts in 1312 days
#8 posted 05-30-2017 11:04 AM
Yeah, I think you probably just got a bad blade Rick. I have a glue line rip I use for the bulk of my ripping and it works great. I will say that I think I get better cut quality if I raise the blade a little higher than I normally would. I normally set the blade so the bottom of the gullet is at the top of the wood. For my rip cuts though, I raise it another 1/4” or so. Don’t know why that’s the case and it’s probably just a peculiarity of my saw but thought I’d throw it out there.
-- Kenny, SW VA, Go Hokies!!!
View EricTwice's profile
EricTwice
237 posts in 707 days
#9 posted 05-30-2017 11:17 AM
Check the teeth to make sure that one is not bent slightly. check the blade for warp.
-- nice recovery, They should pay extra for that mistake, Eric E.
Craftsman on the lake
2822 posts in 3612 days
#10 posted 05-30-2017 11:29 AM
I’ve been using the freud Ice rip blade. It’s not a thin one though. Thick heavy teeth that take out a bit of wood with the cut. And it’s not super smooth like your blade, but it cuts so good and the edge is more than fine for a good glue-up. I don’t joint the edge after. And those huge teeth. Well, I recently had it sharpened at Rocklers, and I expect to sharpen it many more times before they sharpen down too much.
View knotscott's profile
knotscott
8140 posts in 3549 days
#11 posted 05-30-2017 01:15 PM
Probably defective, but regardless, the LM74 has a triple chip grind and won’t leave a flat bottom. You need a Flat Top Grind (FTG) for flat bottoms….LM72, Infinity 010-024, etc.
View rwe2156's profile
rwe2156
3134 posts in 1655 days
#12 posted 05-30-2017 01:17 PM
I have that blade and have to say its by far the best rip blade I’ve ever used.
While you certainly can get a bad blade, I’ve had such good luck with Freud, I would check my saw first.
View GR8HUNTER's profile
GR8HUNTER
4914 posts in 886 days
#13 posted 05-30-2017 01:37 PM
I ve been using the Frued Glue Line rip blade since it was first introduced. I ve never had any problems with it and use it on a daily basis.It s my go to blade for just about everything other than plywood and solid surface material.
- bruc101
- Redoak49
I have that blade and have to say its by far the best rip blade I ve ever used.
While you certainly can get a bad blade, I ve had such good luck with Freud, I would check my saw first.
- rwe2156
DITTO ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ :<))
View Nubsnstubs's profile
Nubsnstubs
1414 posts in 1904 days
#14 posted 05-30-2017 02:49 PM
This Freud blade s specially designed triple-chip tooth design produces extremely smooth, true surfaces for gluing and finish work. There is no need for sanding or jointing after the cut.
- Rick M
I personally have never heard of anyone sanding a saw cut edge before gluing. I just doesn’t make any sense as no matter how purrfect one might think of themselves, that nice flat surface and parallel piece your saw just gave you goes right out the window. And, why would anyone joint an edge to make it smooth for glue?
Do all you folks allow extra width to be able to make that edge smooth? Are all your jointers so purrfect as to keep your boards absolutely parallel?
It’s a known fact especially in painting and in Formica type materials you must scuff the surfaces for the materials to adhere better….. A saw cut that is clean should fit that criteria for gluing. Someone please enlighten me.
For 40 years, I have never used anything other than my table saw, glue, and clamps to glue my work. I worked at a office furniture establishment in California back in ‘78. The oak lumber went through a straight line for width, and then cross cut to 1” longer than final length. After that, straight to the glue station. This was a nationally know furniture manufacturer that made high quality products. I don’t think they even had a jointer in the place. .... Jerry (in Tucson)
pintodeluxe
#15 posted 05-30-2017 03:14 PM
I personally have never heard of anyone sanding a saw cut edge before gluing. I just doesn t make any sense as no matter how purrfect one might think of themselves, that nice flat surface and parallel piece your saw just gave you goes right out the window. And, why would anyone joint an edge to make it smooth for glue?
It s a known fact especially in painting and in Formica type materials you must scuff the surfaces for the materials to adhere better….. A saw cut that is clean should fit that criteria for gluing. Someone please enlighten me.
For 40 years, I have never used anything other than my table saw, glue, and clamps to glue my work. I worked at a office furniture establishment in California back in 78. The oak lumber went through a straight line for width, and then cross cut to 1” longer than final length. After that, straight to the glue station. This was a nationally know furniture manufacturer that made high quality products. I don t think they even had a jointer in the place. .... Jerry (in Tucson)
- Nubsnstubs
Agreed, I would not sand edges before panel glueup.
I think what Freud marketing was getting at is this… a glue line rip doesn’t need the additional cleanup that a standard 24 tooth rip blade might.
I personally joint all boards with opposing passes before glueups. In other words one board is edge jointed with the face away from the fence, and the adjoining board is jointed with the face toward the fence. It helps me get flat panels, and cancels out any error in the fence setting (ie if not perfectly 90 degrees).
If you can get good flat panels straight off the tablesaw, I see nothing wrong with that technique.
showing 1 through 15 of 96 replies
