carba-tec mini lathe turns backwards
« back to Woodturning forum
Forum topic by gogreenwave posted 05-30-2017 12:55 AM 731 views 0 times favorited 7 replies Add to Favorites Watch
View gogreenwave's profile
gogreenwave
2 posts in 602 days
05-30-2017 12:55 AM
Hello,
I just bought a used carba-tec mark II mini lathe so that I could turn a few things every now and then. The only problem is that it turns in the wrong direction. I know I am not crazy, and I could not find a reverse switch. I am not familiar with these lathes. I was able to turn a rattle for my daughter, but I had to do it on the back side of the lathe. Did the previous owner somehow reverse the direction? Any help would be appreciated.
Thanks!
Matt
7 replies so far
View JollyGreen67's profile
JollyGreen67
1676 posts in 3002 days
#1 posted 05-30-2017 01:19 AM
Made south of the equator perhaps ? ;o))
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
MrUnix
7107 posts in 2438 days
#2 posted 05-30-2017 01:45 AM
From looking at the manual, it appears that is using a variable speed DC motor and does not have a reverse. Easy fix though would be to just swap the two wires going to the motor.
View Nubsnstubs's profile
Nubsnstubs
1435 posts in 1969 days
#3 posted 05-30-2017 03:31 PM
I know this has nothing to do with a lathe, but it does fit the question or problem that Matt is having.
I have a MK tile saw that the switch went bad. When I removed it, one of the wires came off the capacitor. After taking the switch apart and defusing the contacts, I put it back together and looked at the capacitor to look for the connector that the one lead came off of. I then connected the wire, and put the cover back on. Well, of course, “off” was now “on” wouldn’tcha know. I figured just get the job done, and fix it later. It did work properly, except the off and on being opposite from before. A week later I had to make about 2 more cuts, and the blade was now rotating in reverse.
As the motor is a Baldor, I called a local Baldor service center and was promptly told that “does not, won’t, and can’t happen”. Got nowhere fast with those guys, so I took the switch/capacitor cover off, and looked even closer at the connectors on the capacitor. I put the lead on another one. I turned the switch on, and the motor rotated in the proper direction.
I have no idea how it went from forward rotation to reverse after that week I used it. I will never know why as if a motor is designed to rotate one way only, it can’t happen. Baldor service said so….. Jerry (in Tucson)
gogreenwave
2 posts in 602 days
#4 posted 05-30-2017 04:34 PM
I switched the wires, and it turns the correct direction now! Thank you! Yeah, I don’t know why switching the wires will switch the direction, I guess because its a DC motor
View Jack Lewis's profile
Jack Lewis
372 posts in 1317 days
#5 posted 06-01-2017 12:21 AM
That is all a reversal switch does anyway.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
runswithscissors
2928 posts in 2264 days
#6 posted 06-03-2017 04:25 AM
Try running it with the motor on the right side, instead of the left.
View Karda's profile
Karda
1383 posts in 793 days
#7 posted 06-03-2017 05:34 PM
that happened to me one but not a lathe, one of those cheap battery operated hand fans. the fan was turning in the wrong direction and blowing air out. I could figure out how to fix it so i put it back together and it worked. I think I put the 2 AA batteries in back wards, that must have changed the polarity
