| Forum topic by Richard | posted 905 days ago | 1541 views | 0 times favorited | 11 replies | ![]() |
905 days ago |
I am making a project with 3/8 inch dowels. My question is, I want the ends to be square-shaped and is there a quick way to do this? I thought about using a disc sander or whittling them with a knife. I am sure I am missing something really obvious. Happy Thanksgiving -- Richard Boise, Idaho |
11 replies so far
#1 posted 905 days ago |
may I surgest you take a square strip cut it a few inches longer than needed take care |
#2 posted 905 days ago |
I was thinking of doing this very sort of thing in an upcoming project. I haven’t gotten around to it, so I haven’t tried it out, but my plan was to: - make a small block with a square cross-section If you are just doing it for looks though and don’t need it to be 100% precise, whittling might be simpler. If anyone else has other ideas, I’d love to hear it them though. -- I do not like work even when someone else does it. - Mark Twain |
#3 posted 905 days ago |
Not real sure I usually start with a square piece and round it with a router except for the ends. If you have a band saw I would think you could make a jig of some sort. -- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy |
#4 posted 905 days ago |
find something made of steel with a square hole just slightly smaller than the dowel, like a mounting plate or something like that then drive the dowel into it and that will give you your square ends minus some sanding -- Potential is limited only by imagination |
#5 posted 905 days ago |
What about cutting square sticks and then using a 3/8 round over bit in the middle sections. Set up start/stop blocks and you will have a minimum of sanding. |
#6 posted 905 days ago |
I believe you use a RO bit half the size of the stock. ie: 3/4” sq stock uses a 3/8” RO bit. Well that is what I do at least. So 3/8th stock would use a 3/16th RO bit. -- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy |
#7 posted 905 days ago |
I think it would be easier to start with a square dowel, and round over the portions that need to be round, rather than the other way around… -- A woman's work is never done-but power tools help! |
#8 posted 905 days ago |
I read this as a different question. Maybe I am wrong but it sounded to me like he has holes to fill that are round, and wants the dowel showing to appear square, as in Greene and Greene style plugs. Not sure of the best method, I know you can make a square plug fit into a round hole with a little persuasion, but this sounds like the reverse to me.. -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#9 posted 905 days ago |
Wow! You guys gave me some excellent advice. I am going to try some experimenting with your tips. Thanks guys -- Richard Boise, Idaho |
#10 posted 905 days ago |
Richard give us an idea what you are making and keep us informed on progress. -- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy |
#11 posted 905 days ago |
Nice way to make it clear Bentlyj. -- Galootish log blog, http://www.timberframe-tools.com |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
