DW734 Pulley crack
Forum topic by greslater04 posted 05-29-2017 01:53 AM 716 views 0 times favorited 4 replies Add to Favorites Watch
View greslater04's profile
greslater04
5 posts in 560 days
05-29-2017 01:53 AM
Topic tags/keywords: planer broken rattle crack dw734
I have a DW734. It started making a loud rattling sound while on. I opened it up and the belt had worked itself loose. I put the belt back on, but the rattle continued. On closer inspection, the pulley on the blade side seemed to be rotating non-circularly. Then I looked closer, and the pulley looked cracked on the inside (See Picture in imgur album). Also, a small part that looks like some sort of set-something fell out.
Any thoughts?
greslater04
5 posts in 560 days
#1 posted 05-29-2017 01:56 AM
Update: I purchased a new pulley, key, and nut from ereplacements. We’ll see how it goes…
View TheFridge's profile
TheFridge
10690 posts in 1682 days
#2 posted 05-29-2017 01:59 AM
It looks like the key in the pics. That couldn’t have been good.
greslater04
5 posts in 560 days
#3 posted 05-29-2017 02:02 AM
Also, somehow the nut worked itself loose because I finally found it on the shop floor… i don’t know if that was cause or result (but I assume cause??)
View EricTwice's profile
EricTwice
246 posts in 730 days
#4 posted 05-29-2017 02:13 AM
The nut probably worked it’s way loose.
check the woodruff key for damage and be sure everything is properly mated in assembly and tighten it. you should be good to go.
-- nice recovery, They should pay extra for that mistake, Eric E.
