I want to make box joints for some drawer innards. I am following the excellent video by William Ng on how to do this. But I am having some problems. I am using a SawStop table saw, a DeWalt dado set and 1/2 inch Baltic Birch plywood from Woodcraft in Cleveland, OH.
After a lot of trial and error, I got things dialed in pretty well. I'm using 1/2" box joint dimensions. I found out that if I orient the plywood so that the veneer is parallel to the saw blade, I get a lot less tear out than when cross-cutting the dado through the surface ply. I guess this ought to have been obvious! However, I am still getting tear out no matter how careful I am. Not too bad, but I'd like better. So I have some questions.
I wonder if anyone has tried cutting some strips of 1/8 inch plywood and placing them between the plywood being box jointed and the fence so that every cut has backing? Probably pretty wasteful of timber and costly.
I read here about the Forrest Box Joint saw set, which was well-regarded, but is apparently limited to 1/4 or 3/8 joints. Any thoughts on using this in 1/2 inch Baltic Birch?
Are there hardwoods less likely to tear out than Baltic Birch? Could make the boxes of pine, poplar or some other solid wood.
Thanks for your input!
