Jointer Help
Forum topic by gav0 posted 11-23-2010 11:16 PM 1076 views 0 times favorited 7 replies Add to Favorites Watch
View gav0's profile
gav0
15 posts in 3433 days
11-23-2010 11:16 PM
Topic tags/keywords: jointer joining question
I purchased 6” poweramtic jointer off of CL a while back and am just getting around to setting it up. It came out of a school shop and had a 3/4hp 3ph motor, I changed it over to a 1.5hp 1ph motor, both are the same speed. I just put new knives in and am having trouble with excessive tear out and the cutterhead wants to grab the workpiece and pull it forward. I’m not real familiar with setting up jointers so any help is appreciated. The depth of cut is set about 1/16”
7 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 2976 days
#1 posted 11-23-2010 11:30 PM
The cutterhead wants to pull the workpiece FORWARD?? Which way are you moving the workpiece?
View gav0's profile
gav0
#2 posted 11-23-2010 11:33 PM
From the infeed table to the outfeed table (R to L, when facing the jointer)
View cabmaker's profile
cabmaker
1696 posts in 2717 days
#3 posted 11-23-2010 11:35 PM
gavo, congrads. on your find. The early powermatics were very nice machines. Dovetail ways no doubt. Your info. is a little sketchy. Are you asking how to set the kinves? If so, basically the top of the arc will set with the outfeed plane. You also mentioned the the cutterhead was trying to pull the work forward. That concerns me. Is the motor running backwards? Can t answer the tearout issue without knowing a few things to wit: wood species, grain orientation, proper knife installation, knife grind,etc. Good luck with it JB
View Lee Barker's profile
Lee Barker
2170 posts in 2758 days
#4 posted 11-24-2010 12:30 AM
From the same perspective, what direction—clockwise, ccw, is the cutter head rotating?
View stevecabinum's profile
stevecabinum
23 posts in 2707 days
#5 posted 11-24-2010 01:03 AM
Sounds like it might be a wiring issue? If the cutterhead is pulling, then the motor is turning the wrong way.
Sawkerf
#6 posted 11-24-2010 01:06 AM
Steve and Lee asked my next question. – lol
When you’re pushing the workpiece, is there any actual cutting – or just a lot of banging as the cutterhead hits the board?
View gav0's profile
gav0
#7 posted 11-27-2010 05:58 PM
You guys are correct the motor is rotating the wrong direction. I pulled it out the other day and it says that it is non reversible, so I just ordered a new 1hp Baldor motor.
