Angle
Forum topic by 19chay12 posted 11-23-2010 08:56 PM 917 views 0 times favorited 4 replies Add to Favorites Watch
View 19chay12's profile
19chay12
3 posts in 2965 days
11-23-2010 08:56 PM
Topic tags/keywords: question
Hi everyone this is 19chay12, I have a question? how do you cut an angle on a pice of wood and what saw do you use. I don’t know what angle it is. Its going thik to thin.thank you.
-- 19chay12
View TheDane's profile
TheDane
5546 posts in 3862 days
#1 posted 11-23-2010 09:12 PM
Not enough information.
Are you talking about something like a table leg?
If so, you could use a table saw and make a tapering jig.
View lew's profile
lew
12426 posts in 3954 days
#2 posted 11-23-2010 09:31 PM
Depends on the width of the board.
You could use a band saw but unless you have a riser kit installed you will be limited to something around 6”. You could use the table saw but again, depending on how high you can raise the blade.
If you have a planer, you could make a jig to run the wood thru with one end higher than the other to form the taper. this would work for a wider board.
View DaddyZ's profile
DaddyZ
2475 posts in 3239 days
#3 posted 11-23-2010 09:42 PM
Again Not enough Information. Bevels can be cut on the router table also, Jigsaw, Mitersaw, Skilsaw, Sander, Etc.
Welcome !!!
View PurpLev's profile
PurpLev
8547 posts in 3847 days
#4 posted 11-23-2010 09:48 PM
yes. you do have a question.
