Guessing how much poly is needed to be used upon a project before hand
Forum topic by Holbs posted 05-26-2017 03:59 PM 1316 views 0 times favorited 7 replies Add to Favorites Watch
View Holbs's profile
Holbs
2002 posts in 2226 days
05-26-2017 03:59 PM
Topic tags/keywords: poly finishing hvlp
I am spraying a project for the first time using my Summit HVLP system. I’m happy with it (for a beginner). I have so far sprayed 2 coats upon roughly 4 window jamb pieces of 5’x4” knotty alder boards. I’m nearly 1/2 out of my quart. Unsure if I am using “too” much or if this is about right for the amount. This leads to future project questions. Is there a rule of thumb in regards to how much medium (poly, varnish, etc) to have on hand prior to starting a project? Something like a quart for so many board feet? I may toss on a 3rd coat depending on what I see from my 2nd coat later tonight. Can already tell, will need another quart for the casings.
7 replies so far
View Rich's profile
Rich
3865 posts in 786 days
#1 posted 05-26-2017 04:27 PM
That’s the sort of thing I keep notes on as I work, so that I can use that information to plan in the future. You’ll also simply develop a gut feel as you gain experience with your sprayer. The sq-ft per gallon, or whatever, on the can is for brushing — and even it is an approximation based on typical application. You have different variables with your sprayer, such as what flow rate you’ve set, overspray, etc. Overspray is really the key, because that’s finish that’s being used up, but not getting on your surface. I’m not sure if anyone can give you a definitive answer because of those.
Edit: I always buy more than I need. Gallon cans are more economical per ounce than smaller quantities. To keep it from going bad, I keep those cheap empty paint cans you can get for a couple of bucks around, and divide up the gallon into four quart-size ones of those. Label them, and you’re all set. It will save money, and the cans are re-usable.
View pintodeluxe's profile
pintodeluxe
5797 posts in 3010 days
#2 posted 05-26-2017 05:03 PM
About twice what you think you need.
I spray lacquer more often than anything else, but I notice the second coat doesn’t eat up as much finish as the first.
I used to buy in 5 gallon quantity, but now just get gallons.
View AandCstyle's profile
AandCstyle
3177 posts in 2453 days
#3 posted 05-26-2017 09:40 PM
Holbs, another consideration is the shape of the pieces you are spraying. Less product per square foot is required for large pieces than for small ones because there is much less waste. Your current project will need more finish than the same square feet if you were finishing a cabinet, for example. I agree with the others that gallons are the best way to buy finish balancing price and usage.
-- Art
View hotbyte's profile
hotbyte
991 posts in 3172 days
#4 posted 05-26-2017 09:57 PM
I always seem to need 3 more oz than I have on hand ;-)
Holbs
#5 posted 05-26-2017 10:17 PM
OK…gallons it is. Especially considering the future plantation shutters & casing projects I have coming down the road. 5 gallons, maybe :)
Holbs
#6 posted 05-27-2017 12:17 AM
For those new to HVLP and poly and finishing… that is where I am right now. I’ll admit, I did not even read the instructions on the side of my quart can:) It does not state an estimate of coverage on the label, however the website of the manufacturer clearly states a single quart can do 125 sq ft coverage. If my wood working mathematical Deep Blue computations are right, I am working on roughly 80 sq ft of space (4”x60”x4 / 12 = 80) using a HVLP which does have overspray..and I have 1 more coat to put down. I would guesstimate, I’ll have 15-20% left over in the can.
View Rich's profile
Rich
#7 posted 05-27-2017 01:17 AM
Take the integral and perform a Laplace transform, then run it through a Dirac delta function, and you’ll have your answer. BTW, the answer is always 42.
Back to reality, the main thing with gallons, etc, is that air space in the can will oxidize the finish, so that’s why I said to pour a gallon into quart cans. The fully filled quart cans will keep as long as the shelf life of the gallon.
