Cabinet Design Flaw ??? Any Solutions ???
Forum topic by Brett Lowing posted 940 days ago 1636 views 0 times favorited 21 replies Add to Favorites Watch
View Brett Lowing's profile
Brett Lowing
23 posts in 966 days
940 days ago
Topic tags/keywords: question cabinets flaw
I had someone come to me with a unique cabinet design problem. The upper corner cabinets are recessed and swing open into each other making the storage space very difficult to access. My first thought would be to attach the doors together and build some sort of slide system to clear the 2.5” recess and have it hinge from there.
Any ideas and thoughts would be greatly appreciated!
-- "Choose a job you love, and you will never have to work a day in your life." - Confucius
21 replies so far
Brett Lowing
#1 posted 940 days ago
That’s the plan, but I still need to clear the recess to be able to open the door fully.
View SCOTSMAN's profile
SCOTSMAN
4335 posts in 1783 days
#2 posted 940 days ago
Don’t you think folding opening outward doors would be better hinged at one end and centre looks like one big folding door .Or look up kitchen manufacturers corner cupboards and see all the different types of hinges.Alistair
Brett Lowing
#3 posted 940 days ago
Yeah, but I still need to be able to pull the door out passed the 2.5” recess to open it fully. Otherwise it’s still hard to access.
View RONFINCH's profile
RONFINCH
142 posts in 1122 days
#4 posted 940 days ago
I think I would try a lazy susan set up, where both doors would turn into the cabinet, exposing the contents.
Brett Lowing
#5 posted 940 days ago
That’s not a bad idea but the cabinet is more shallow that the standard 12” and there wouldn’t be enough room for the doors to revolve.
View traupmann's profile
traupmann
123 posts in 985 days
#6 posted 940 days ago
Bi-fold with an overlay hinge should do the trick
-- chas -- looking for Serta sponsorship to go Pro...
View Gregn's profile
Gregn
1639 posts in 1181 days
#7 posted 940 days ago
This might sound stupid but I have see this done on doors a bit smaller. How about joining the 2 doors together forming a V shape door and use a piano hinge on one side so that it opens as one V shaped unit.
Brett Lowing
#8 posted 940 days ago
I want to be able to pull the doors out past the cabinets on either side and open with the hinge from there. Anyone know of a shallow slide system? So I’ll end up mounting the door hinges to the slide system I build.
Brett Lowing
#9 posted 940 days ago
The doors will be joined with hinges.
View PurpLev's profile
PurpLev
7819 posts in 1846 days
#10 posted 940 days ago
could you swap the entire hinge system with sliding hinges?
if would mean a major change to the internal of the cabinet – but in the long run, I think your client will love you for it and it’ll take all the mickey mousing with the doors out of the picture (pun intended)
Brett Lowing
#11 posted 940 days ago
That’s what I’m looking for! Thanks! Looks expensive though. Do you know where to get that and an approx. cost? Hopefully it can fit shallow cabs too.
View canadianchips's profile
canadianchips
1781 posts in 1195 days
#12 posted 940 days ago
Reverse the doors. Hinges in the center opening door against the other.NOT IDEAL but would give them better access than they have now. Sadly only one could open at a time though. Sliding hinge are great, you will have to figure out a way to attach the shelfs .
Brett Lowing
#13 posted 940 days ago
And I would have to add a piece in the face frame to attach the hinges to. That’s at least a cheap option. Thanks!
View MrsN's profile
MrsN
920 posts in 1724 days
#14 posted 940 days ago
Is there a way to add a hinge to the middle of one of the doors (well maybe 3” in) so that it could fold flat against the other cabinets and allow better access to the cabinet. I am not fluent in hinges and the only ones I can think of would be very visable and not pretty, but maybe there are others.
-- ----- www.KNWoodworking.com ----- --
View Seeharlez's profile
Seeharlez
82 posts in 1191 days
#15 posted 940 days ago
Here is an idea that should work. Make each door ‘L’ shaped and move the hinge point out to the front edge of the recess. See picture for detail…
-- Greg - Vancouver, BC
