Problem with Making Drill Press Auxiliary Table
Forum topic by ChrisCarr posted 11-22-2010 05:40 AM 1371 views 0 times favorited 5 replies Add to Favorites Watch
View ChrisCarr's profile
ChrisCarr
196 posts in 2773 days
11-22-2010 05:40 AM
Hello All, I have run into a bit of a problem when trying to make a wooden aux. table for my drill press. I thought someone might have an answer. My press’ current table is about 1/3 the size of the plywood one to go over it. Its just 1/2” thick plywood with solid spruce rabbetted around the edges and 2 spruce support glued under the ply. The new table is dead flat as i checked before i put it on the cast iron one but once its clamped onto the cast iron one it is not flat anymore. It isn’t flat in the areas where the cast iron isn’t under it. It appears to bend when clamped.
Would making a thicker table fix this? Could I fix this without redoing the table?
Thank you.
- Chris C.
5 replies so far
View wseand's profile
wseand
2796 posts in 2916 days
#1 posted 11-22-2010 05:56 AM
I am not sure why it would bend when you clamp it down uless the clamps are pulling it at a odd angle. If you could upload a few pics that might help to get a better idea of your problem. Sorry I am a visual person. You might try more supprt closer to where it sits on the table. Or try finding a different way to fasten it down besides clamps.
View PurpLev's profile
PurpLev
8534 posts in 3523 days
#2 posted 11-22-2010 06:02 AM
depending on where the 2 spruce support are – they may not provide the proper support needed.are they going cross? or length wise? does the plywood bolt directly to the cast iron table? or are the support between the plywood and the cast iron? (the plywood should be bolted directly as any gap between them will cause the plywood to bend is too much pressure is put on the bolts)
that aside – 1/2” sounds a bit on the light side of things. you would be far better off with simply using 2 3/4” or at least 2 1/2” plywood panels laminated together and you won’t need any additional support braces.
View Robsshop's profile
Robsshop
904 posts in 2849 days
#3 posted 11-22-2010 06:17 AM
Chris,pics would help to diagnose but with Your description it seems if your table is flexing under clamp pressure !Perhaps it is from over tightening of the clamps,once again its hard without a visual . For most drilling operations on a drill table it is not necessary to apply so much clamping force, I use two set screws at the base of drills plate to hold my auxilery table in place .
-- Rob,Gaithersburg,MD,One mans trash is another mans wood shop treasure ! ;-)
View Howie's profile
Howie
2656 posts in 2797 days
#4 posted 11-22-2010 02:32 PM
Glue a piece of 3/4 MDF on top.(or bottom)
-- Life is good.
View Gregn's profile
Gregn
1642 posts in 2858 days
#5 posted 11-22-2010 09:06 PM
I made a down and dirty one from 3/4” plywood with a oak fence and bolted it directly to the cast iron table with 2 carriage bolts and have had no problems with flatness. As stated pics would be a big help, to give advice on.
