New Grizzly G0771Z
Forum topic by orion7144 posted 05-23-2017 11:06 PM 2934 views 0 times favorited 16 replies Add to Favorites Watch
View orion7144's profile
orion7144
24 posts in 615 days
05-23-2017 11:06 PM
I will be receiving it on Thursday and have a couple of questions.
I will not be installing the stock fence since I ordered a Vega Pro 40 for my Ridgid r4512 but decided I wanted (and was given permission) to upgrade. I will also be installing the cast iron router extension I had on my Ridgid.
Does anyone see an issue with the above plans? I plan on installing the router extension to the table. Do you think it is possible to add the stock wing to it? Or should I just build a wood extension?
Does anyone have any tips for assembly?
If anyone is interested in the newer fence system for the non “Z” just message me. I do not plan on opening it.
16 replies so far
View knotscott's profile
knotscott
8174 posts in 3611 days
#1 posted 05-23-2017 11:46 PM
There should be no reason you can’t add the stock extension and your router table….that’s exactly what I did with my Shop Fox saw. Should be no problem with the fence either.
orion7144
#2 posted 05-25-2017 09:02 PM
Received the saw today. Waiting for help tomorrow to get it in my basement. I took both wings out of the box and was curious why one felt heavier than the other. I weighed them and one is 35.6lbs and the other is 31.1lbs.
orion7144
#3 posted 06-29-2017 10:12 AM
Sorry for the delay but I finally have my saw put together and setup. Here is a picture.
orion7144
#4 posted 06-29-2017 10:15 AM
And here is how I mounted the power switch since I used the Vega instead of the stock system.
Only complaint is the dust collection. I sealed the inside but I think there should be some kind of cover for the slot the wheel travels when beveling.
View JRsgarage's profile
JRsgarage
335 posts in 745 days
#5 posted 07-12-2017 11:24 AM
Orion7144, have you had a chance to use the your new fence? how do you like it? thanks
-- Two is One, One is None
View richardchaos's profile
richardchaos
583 posts in 615 days
#6 posted 07-12-2017 11:42 AM
I have two Grizzlie power tools and am not impressed
-- β€œIn a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
View BigPimpin's profile
BigPimpin
12 posts in 618 days
#7 posted 07-12-2017 12:07 PM
I’ve got one of these and absolutely LOVE it. I swapped out stock the fence for an Incra and its even better. It never occurred to me to seal the stand for better dust extraction. I will be looking into this later today. I also have a grizzly bandsaw and an G0490x jointer. Could not be happier with my Grizzly stuff. Unless the machinery that you got was defective when you got it, I suspect user error could be an issue with those not happy with grizzly….
orion7144
#8 posted 07-12-2017 01:13 PM
I love the Vega but can not compare it to the stock one since I never installed it. I had the Ridgid before and it had a similar fence to the grizzly stock one but the vega is accurate every time.
JRsgarage
#9 posted 07-12-2017 01:20 PM
thanks. considering making the switch after seeing yours..
BigPimpin
#10 posted 07-12-2017 01:26 PM
Also have an Incra router table and lift bolted to the thing….
View Paradox's profile
Paradox
8 posts in 2644 days
#11 posted 07-12-2017 02:55 PM
Here’s mine. The saw table is all cast iron. The router extension is from Peachtree. I used the Peachtree product because it has a larger opening which fit the table insert plates I already had.
View MisterJerry's profile
MisterJerry
2 posts in 553 days
#12 posted 07-13-2017 02:55 PM
Which Shop Fox saw is this Grizzly the equivalent to? I’m not wrong that these two manufacturers use the same base saws, right? I really like the W1819, but the reviews and amazon feedback I have found don’t give a lot of info in that regard.
Just curious because I also know I will want to add a router extension and wonder if the above comments apply.
knotscott
#13 posted 07-13-2017 07:11 PM
Which Shop Fox saw is this Grizzly the equivalent to? I m not wrong that these two manufacturers use the same base saws, right? I really like the W1819, but the reviews and amazon feedback I have found don t give a lot of info in that regard.
- MisterJerry
AFAIK, the W1819 is pretty much the same saw as the Griz G0690 under the hood. It looks like the SF W1837 has the same guts as the G0771, and the W1824 is the same as the G0715P.
View bret0826's profile
bret0826
6 posts in 551 days
#14 posted 07-16-2017 09:33 PM
richardchaos-what was the point of your comment.he wasn’t asking for advice in picking out a new tablesaw,he just had it delivered and is probably thinking of all the good times he is going to have.sorry but d—ckhead move on your part
View EgyWooder's profile
EgyWooder
1 post in 270 days
#15 posted 04-22-2018 09:14 PM
- orion7144
I am curious to know what Extension Insert you used for this setup. I am looking to get the G0771Z and looking for router insert to with it
