| Forum topic by jeepturner | posted 909 days ago | 614 views | 0 times favorited | 10 replies | ![]() |
909 days ago |
Topic tags/keywords: question bandsaw So as I was looking at Craigslist the last month for a good used bandsaw, I came upon a add from Woodcraft for a 14” Rikon for $699.00. I decided to get the new Rikon, drove down and picked it up today. The new one was about what I wanted to spend on a used one. It has all the features I was looking for except one, the brake. I just put it together and have set the guides. The blade is oscillating about .020” to .030” at the kerf plate. -- Mel |
10 replies so far
#1 posted 909 days ago |
I’ve never measured my oscillation but my intuition tells me that this is too much. Without using a meter, I observe virtually no oscillation of my blade. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#2 posted 909 days ago |
Rich, thanks for the response. I would like to ask you a question about co-planer wheels. I my mind I think of co-planer wheels that I should be able to set a straight edge across both wheels and the straight edge would touch at all four places. Is this correct? -- Mel |
#3 posted 909 days ago |
Rich, thanks for the response. -- Mel |
#4 posted 909 days ago |
Jeepturner, I too have the Rikon 14” and love my saw. I don’t have any oscillating at all… Is it front and back or side to side? If it is front to back be sure to back off on the back roller above and below the table, and then see if the oscilliating stops. Good Luck! -- Chuck Emery, Michigan, |
#5 posted 908 days ago |
Thanks Chuck, -- Mel |
#6 posted 908 days ago |
I had the same problem on my PM BS when I got it. The wheels were not co-planer. I had the riser kit too so I’m not sure if I would have had the problem without but I’m sure the riser added to it. After talking to the manufacturer I enlarged the guide pin holes it the riser so there was more play in it. After adjusting it for about an hour I got them co-planer. |
#7 posted 908 days ago |
Mel, I would say that you have a bad blade. A straight edge should touch the wheels at 4 points. -- Bert |
#8 posted 908 days ago |
I think Bert is right. Get a new blade(a good one most saws come with losey blades) and try it again. Double check all your guides again to make sure nothing slipped. -- Don't rollerskate in a buffalo herd |
#9 posted 908 days ago |
#10 posted 908 days ago |
The first thing I did to the saw was to remove the blade and install a three tpi timberwolf. I don’t think it is the blade, one because I fed the blade by hand with a position sensor, and marked the blade when it was at the most aft position, and two because the wheels are not coplanar. Where I marked the blade as oscillating aft, it never repeated at the same spot. -- Mel |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
