Gluing up narrow oak for thick table legs
Forum topic by Gator posted 11-22-2010 01:18 AM 11367 views 3 times favorited 12 replies Add to Favorites Watch
View Gator's profile
Gator
382 posts in 3585 days
11-22-2010 01:18 AM
Topic tags/keywords: table legs oak tip question milling joining shaker
I am starting to build a hall table for the LOML. The design I am using has 2.5” tapered legs. I have a bunch of Red oak, but it is all 4/4. I thought I saw an article about glueing up 3/4” boards to make table legs in a way that would give you the grain on the two sides you can see. My lumber is not 1/4 sawn.
I would think I will need to glue up 4 boards of 3/4” each and then plane them to final dimension, but am not sure how to arrange the grain for the glue up, or if this is even possible?
Any help would be appreciated ..
Gator
-- Master designer of precision sawdust and one of a kind slivers.
12 replies so far
View TheDane's profile
TheDane
5367 posts in 3572 days
#1 posted 11-22-2010 02:10 AM
I’m doing a project now where the legs need to be 2 1/8” square … I had a bunch of 4/4 stock that I planed down to 3/4” and ripped to 2” wide.
On each piece, I cut a rabbet 3/4” wide and 5/8” deep, then glued the four sides together.
The space in the middle is open, so they are hollow, and I chamfered the corners, which effectively hides the glue joint.
Gator
#2 posted 11-22-2010 03:00 AM
That is a great idea, but I am not sure how it would work on the tapered legs. I may have to re-think the legs, and go with a straight leg .. the table dimensions are 44” x 15” x 29”. I was worried straight legs would make it look too “boxy” .. but if I can’t come up with something I will try your method and see if I can make it work.
Thanks.
View Lee Barker's profile
Lee Barker
2170 posts in 2759 days
#3 posted 11-22-2010 05:19 AM
Dane’s construct is elegant and nifty, but the taper can be real critical visually—kudos to you for being sensitive to that.
Your idea will work, and you’ll have fun finding the best way to arrange the leg pieces. My one suggestion is that, once you have glued them up and trued them and cut them to length (prior to tapering), mark the tops so you know what two surfaces face outside.
Also, know that you can taper just two surfaces and get a good result—it doesn’t have to be all four.
View Gregn's profile
Gregn
1642 posts in 2892 days
#4 posted 11-22-2010 08:37 PM
Does this help?
http://lumberjocks.com/bsherman/blog/12526
At least it gets to the idea although its about repair it shows how he did the glue up.
Otherwise try Googling Quadrilinear legs.
TheDane
#5 posted 11-22-2010 09:00 PM
Gator … A lot of Mission/A&C furniture uses straight legs, but adds corbels which can provide some of the visual effect you get from a tapered leg. A set of corbels might do the trick for you.
Gator
#6 posted 11-23-2010 02:14 AM
Thanks guys… I was only planning on tapering the insides.. sorry I should have mentioned that, but I am always open for options.. I am actually going to try a glue up of Danesidea, and see what I can make work, as the more I think about it.. the more I like it.. possibly calculate how much I can taper the inside two faves, and then round over the two outside edges.. ?
I will not be able to get into the shop for a few days as I just have too much on my plate rigt now.. but it gives me a few days to rethink my design. If I was any good with sketchup I would post my idea.. but it is only a hard copy at this point.
Gator
TheDane
#7 posted 11-23-2010 03:14 PM
Gator—- Just a quick post-script … think about doing the glue-up, do it in stages. The first time I did one of these I tried to glue all four sides at one time … not a good idea. It was hard to manage and I had a h@!! of a time getting the clamps on. On my current project, I glued/clamped two sides together to form a V, let the glue dry, then gluded/clamped the V’s together.
—Gerry
View Pick's profile
Pick
30 posts in 2942 days
#8 posted 11-23-2010 04:48 PM
I really like TheDane’s idea, until he mentioned doing the glueup in stages. Have you considered a lock-miter bit? Benefits: The outside glue line ends up exactly on the corner, looks no different than a standard miter-joint—-AND, the extra ridges in a lock-miter aid in assembly, not allowing things to slide around. I recently used it in making some 3×3 maple legs for a coffee table.
TheDane
#9 posted 11-23-2010 05:11 PM
Pick is right … I just don’t happen to have a lock-miter bit set (I see them listed for $60 and up). I did all of my cutting on the table saw.
Lee Barker
#10 posted 11-23-2010 05:43 PM
Low tech solution which really works (from my friend Greg Fulton, a master woodworker):
Prepare ample stock. for 16 staves, I’d make 18 or 19. Half inch over length would be fine. You may end up rejecting a couple.
Miter them and then arrange them in a way that pleases your eye.
Keeping them outside-up, tape across three joints with 5 or 6 pieces of masking tape, leaving a tag end to complete the last joint.
Flop the tambour over and spread your glue and roll the boards up like an enchilada, taping it tight.
At this point, traditional clamps will just give you apoplexy. Leave them hanging on the wall, and clamp it with rubber or 4” shrink wrap.
If your saw blade is sharp (and you have a blade stiffener) and your angle is true, you have very good looking miters. You may need a little putty, but only the resident hamsters will be aware of that.
View ChristopherHawkins's profile
ChristopherHawkins
6 posts in 1616 days
#11 posted 01-24-2015 02:34 PM
Lee’s suggestion from Greg Fulton makes a lot of sense to me and I’m looking forward to taking a look at some of his other posts.
View Craftsman on the lake's profile (online now)
2742 posts in 3346 days
#12 posted 01-24-2015 02:48 PM
I find that if you glue them without rabbeting them and are a little careful with the grain choice, the seam will hardly be noticable. It’s all edge grain.
