"Thin" Heartwood Pine for a Table Top
Forum topic by wkerr posted 05-23-2017 03:33 PM 876 views 0 times favorited 7 replies Add to Favorites Watch
View wkerr's profile
wkerr
10 posts in 2889 days
05-23-2017 03:33 PM
Topic tags/keywords: question pine joining
I have lots of ships lapped heart pine coming out of the house that my grandparents lived in most of their lives. This material, when planned and ready for joinery will be around 5/8 inch thick. I really want to build a table top out of this for obvious sentimental reasons, but I’ve yet to settle on a solution for the thickness. looking for suggestions on how to build this top. I thought about using a substrate but not sure if that’s reasonable or not.
Thanks in advance.
7 replies so far
View LittleShaver's profile
LittleShaver
419 posts in 817 days
#1 posted 05-23-2017 05:55 PM
A layer or two of plywood should serve nicely. Consider edge banding the ply with strips of pine.
-- Sawdust Maker
View jdh122's profile
jdh122
1052 posts in 3015 days
#2 posted 05-23-2017 07:10 PM
Do you have enough to double the thickness by laminating two thicknesses together? That would bring you to just over an inch thick, which is visually about right to my eye.
A plywood substrate will probably work, but I’d worry a bit about wood movement gluing the wood to the plywood, given that the plywood will be more stable than the pine. It might be OK since pine is pretty dimensionally stable.
-- Jeremy, in the Acadian forests
View Rich's profile
Rich
3871 posts in 787 days
#3 posted 05-23-2017 07:24 PM
Folks use plywood as a base for veneer all the time. Not the thin, paper-backed stuff either. If he’s attaching shiplapped boards, they aren’t going to move across the grain enough to matter.
I think Dan pretty much nailed it.
View Carloz's profile
Carloz
1147 posts in 789 days
#4 posted 05-23-2017 08:20 PM
- Dan Hulbert
one should be very careful taking free advice from internet
View TungOil's profile (online now)
TungOil
1055 posts in 693 days
#5 posted 05-23-2017 11:23 PM
5/8” would be too thick to veneer, I wouldn’t go thicker than 1/8” for veneer glued to plywood cores and even then you need to use a urea formaldehyde glue like Weldbond to assure it won’t creep over time. I think Jeremy has the right idea, if you have enough material to glue up two thicknesses you can create some thicker boards that you can then glue up like a thicker solid tabletop.
Also, as someone who is in the middle of making a table from shop sawn veneers over ply core, I can tell you it’s a huge amount of work compared to just gluing up a solid top and you’ll need a vacuum press to really make it look right when it’s done.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Woodknack's profile
Woodknack
12430 posts in 2578 days
#6 posted 05-24-2017 01:04 AM
Do not attach plywood to the bottom of the tabletop. If you want to make it appear thicker, glue a second layer on the bottom, around the edges only.
https://wunderwoods.wordpress.com/2013/09/17/how-to-make-a-thick-countertop-out-of-thin-wood/
View ADN's profile
ADN
193 posts in 811 days
#7 posted 05-31-2017 03:56 PM
If the pine heartwood is that thick 5/8 then no reason to glue it to the substrate, just edge band it with a rabbet (lip) to capture the substrate. You can even do a few elongated holes with screws and washers if required.
I’ve made several islands and bar tops using this method and it works great…
Andy
-- mos maiorum
