Daddo shim problem
Forum topic by jimmy J posted 05-23-2017 01:54 AM 644 views 0 times favorited 6 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2499 days
05-23-2017 01:54 AM
In the pics, you can see each shim has been deformed around the center hole. On one, the edge of the hole has a bulge making it not flat. On the other, a small piece near the center edge has been sheared away. Is this caused by the arbor nut being too tight? Other cause? Perhaps due to the shim sitting in the arbor nut grooves and then getting pressed?
View TheFridge's profile
TheFridge
10131 posts in 1606 days
#1 posted 05-23-2017 02:33 AM
You hit the nail on the head. It’ll slip into the threads and get messed up when tightening.
jimmy J
#2 posted 05-23-2017 02:42 AM
What’s the trick to avoiding this in the future?
View Carloz's profile
Carloz
1147 posts in 712 days
#3 posted 05-23-2017 04:01 AM
No tricks, it going to happen sooner or later. There are magnetic shims that lower the chance of pinching
TheFridge
#4 posted 05-23-2017 05:26 AM
Pretty much
View pintodeluxe's profile
pintodeluxe
5741 posts in 2934 days
#5 posted 05-23-2017 05:36 AM
Infinity dado sets come with plastic shims and they don’t seem to have that problem.
You might see if they sell the shims separately.
View bondogaposis's profile
bondogaposis
4931 posts in 2472 days
#6 posted 05-23-2017 12:38 PM
I have been using playing cards for shims, they don’t have that problem. Each card equals 1/100”.
-- Bondo Gaposis
