Wood stove in my attached garage (Workshop)
Forum topic by CovenantCreations posted 11-21-2010 08:23 PM 3177 views 0 times favorited 5 replies Add to Favorites Watch
View CovenantCreations's profile
CovenantCreations
127 posts in 2868 days
11-21-2010 08:23 PM
I just moved into a new place this summer, and have since been working on setting the garage up as my woodworking shop. Although a vehicle may occasionally get pulled in if it needs to be worked on or thawed out. Anyways, I have really been debating the use of a woodstove, Ive got an old cylinder style stove and the piping, and dual walled insulated chimney piping for it. I have been doing a lot of research on it, and have used woodstoves before, but not a whole lot. The main things that keeps me questioning is the fact that it is attached to my house, and I would hate to have a fire. Currently I have an electric heater mounted in there, which works good now, but I have a feeling when it gets down to 20 below, it may have a tougher time. It would also be nice to be able to burn up all my woodscraps I don’t want.
What would you do? I appreciate the input, as ol man winter is knocking on the door.
5 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3678 days
#1 posted 11-21-2010 08:55 PM
Be careful with your insurance, sometimes woodstoves/fireplaces adversely affect you insurance. I suspect if you do not tell the insurance company and you have a fire (or even any other claim) and they ‘find out’ about the woodstove your insurance may be void!
I personally would love to have a wood stove, and someday I may check out what is involved in installing one in the shop but for now I am using an electric heater.
View TheDane's profile
TheDane
5399 posts in 3628 days
#2 posted 11-21-2010 09:39 PM
Gets pretty cold here in Wisconsin, too, and my electric heater ( http://lumberjocks.com/reviews/1161 ) does a pretty good job. My garage is well insulated, and even on the coldest days, it only takes a few minutes to warm it enough that I am comfortable in a sweatshirt (sleeves cut off at the elbow).
CovenantCreations
#3 posted 11-22-2010 02:04 AM
Dane, thats actually the same heater I currently have hanging in the garage. How does it do on those 20 below days? I think if I just insulate the garage door and get rid of a few air leaks, the heat will stay in much better.
TheDane
#4 posted 11-22-2010 02:14 AM
It is terrific … I turn it on about 15 minutes before I go out to the garage/shop. My garage only has two outside walls, and has the living room above it, plus a pretty high-end steel, insulated garage door.
View cabs4less's profile
cabs4less
235 posts in 2728 days
#5 posted 11-22-2010 03:04 AM
i use a wood stove in my shop it sit in the middle of the back wall i love it but i live in south alabama so when it is at its coldest here which is like 30 the stove keeps me warm i never had any probs wit a fire but you being used to a wood stove know that once you get some good coals in there then you dont need a flame so to speak
-- As Best I Can
