Finish Question
Forum topic by wannadoitall posted 941 days ago 638 views 0 times favorited 6 replies Add to Favorites Watch
View wannadoitall's profile
wannadoitall
56 posts in 992 days
941 days ago
Okay, this is a little embarrassing – I can’t remember at all whether or not I already asked this – if I did I can’t find any history of it, so maybe I didn’t. If I did, bear with me again…
My current project is from a bunch of wood that I literally tore apart from an old bed frame. I have “refurbished” the wood as best as I can, which includes a whole lot of spots of wood filler (Famewood brand). It’s just about ready to be finished now, and I am trying to figure out what stain will work best for it. Something that will look as consistent as possible throughout, including the wood filler parts.
Any ideas? Thanks guys.. or maybe, thanks again! :)
-- -Angela, "Christos Anesti!"
View lilredweldingrod's profile
lilredweldingrod
2493 posts in 1303 days
#1 posted 941 days ago
Any idea of what wood you are working with? Is this plywood? Hardwood?Pine? ??? We are in the dark here. How about a picture or two or three?
View shipwright's profile
shipwright
3479 posts in 994 days
#2 posted 941 days ago
If you are spraying, you might consider toning rather than trying to get a stain to match on wood and filler.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
wannadoitall
#3 posted 941 days ago
shipwright – good idea! i’ll look into that…
lilredweldingrod – sorry, i’m a little in the dark here myself. as it was just wood from an old bed frame – that wasn’t even mine originally, i have no idea what kind of wood i’m working with. my thoughts are that it is either pine or fir or some variation thereof…
View Cosmicsniper's profile
Cosmicsniper
2155 posts in 1355 days
#4 posted 941 days ago
Since the wood and filler absorb at differing rates, there’s always the risk that using a stain will yield unsatisfactory results.
To play it safe, I like to sealcoat it and then tone it like shipwright mentioned. You can then control the amount of color without it being absorbed into the wood (and filler). Whereas you obscure the grain in this way, that’s not always a bad thing. It’s a good technique for cabinetry, whereas you can keep a subtle appearance of the wood grain and yet get the color you want. After toning, you can then glaze to add depth or effects to the work.
If you stain, then you can always touch-up the filler spots (sealed it) to match the stain. Then, when you top-coat it, nobody is the wiser for it.
But I like toning it, especially when dealing with projects with reclaimed wood or mixtures of plywood and hardwood. Color is much easier that way.
-- jay, www.allaboutastro.com
wannadoitall
#5 posted 941 days ago
Thanks Cosmicsniper! Great info, I didn’t think about the sealcoat idea. I think I may just try doing it this way. Thanks a lot!
View Ron Henricksen's profile
Ron Henricksen
31 posts in 1282 days
#6 posted 939 days ago
i have used this Clear Sealcoat (shellac) – Stain – Poly approach with one of my first cabinets that ended up containing three kinds of wood. Stained it oak as most of the project was red oak and the results were excellent I see that cabinet every day and am amazed it worked. There was even some wood filler in the corners that turned out ok. Good luck with it.
-- Ron, Aptos, CA
