Thickness for cherry storage chest/bench
Forum topic by JoshinDC posted 05-21-2017 07:23 PM 539 views 0 times favorited 7 replies Add to Favorites Watch
View JoshinDC's profile
JoshinDC
5 posts in 458 days
05-21-2017 07:23 PM
I’m in the design stage of building a storage chest that I also intend to use as a bench at the foot of my bed. The sides will be frame and panel construction, and the rough dimensions will be 48” wide, and 18” deep. I’m second guessing myself on the thickness needed for the top. It will be supported around all 4 edges, but needs to support the weight of a ~200lb adult daily without harm. I plan to make it from cherry boards edge-glued together.
I was thinking of making it from 6/4 stock, but I’m wondering if that will be overkill. This is my first project working with hardwood, and this seems like one of those things I will eventually just have a feel for, so I figured I’d ask for advice. Thanks in advance for your help!
Josh
7 replies so far
View Loren's profile
10477 posts in 3734 days
#1 posted 05-21-2017 07:50 PM
4/4 is fine. It takes a lot of force to break
a 3/4” thick piece of hardwood.
#2 posted 05-21-2017 07:52 PM
View rodneywt1180b's profile
rodneywt1180b
167 posts in 473 days
#3 posted 05-22-2017 08:13 PM
3/4” finished size is plenty strong enough.
Rodney
-- Rodney, Centralia, WA, USA www.etsy.com/shop/ASturdyStick
View LittleShaver's profile
LittleShaver
346 posts in 706 days
#4 posted 05-23-2017 06:04 PM
Loren:
Awesome link. Thanks for posting.
JoshinDC:
No problem using 3/4 material for the top. I have a tool box about 24×36 with 1/2 ply lid panel that I have no problem sitting on.
-- Sawdust Maker
View jmartel's profile
jmartel
8067 posts in 2236 days
#5 posted 05-23-2017 06:15 PM
4/4 is fine for the top, but generally speaking, thicker tops look better.
View rwe2156's profile
rwe2156
3036 posts in 1567 days
#6 posted 05-24-2017 12:03 PM
The problem with 4/4 for tops is yes you may get a 7/8” if you’re boards are nice and straight and behave well during milling. But that rarely happens so start big and give yourself less headache.
For tops I start with 5/4. Often this is 1 1/8” actual thickness, so material selection is still crucial.
6/4 may be necessary depending on bows, cups, etc, but would be more wasteful.
View bonesbr549's profile
bonesbr549
1569 posts in 3153 days
#7 posted 05-24-2017 12:52 PM
Me i work with what i got. If I got 5/4 handy then it will be 4/4 finsished. If I got 4/4 then it will be 3/4 finished.
Even if its only 5/8” or 1/2” if engineered properly it will be fine.
Go with your gut.
