band saw blade
Forum topic by Karda posted 05-21-2017 03:28 AM 441 views 0 times favorited 6 replies Add to Favorites Watch
View Karda's profile
Karda
1382 posts in 792 days
05-21-2017 03:28 AM
got a new band saw blade was checking the tracking and the blade stopped dead, a tooth was bent and stopped the blade. What should I do contact the dealer or straiten the bent tooth. thanks Mike
View papadan's profile
papadan
3584 posts in 3606 days
#1 posted 05-21-2017 03:36 AM
If it is just one tooth, I would straighten it. If it is more than one, I would send it back as defective.
View Loren's profile
10477 posts in 3886 days
#2 posted 05-21-2017 03:37 AM
If you don’t have a saw set you might
use a pair of needle nose pliers to bend
the tooth back towards the center. It doesn’t
have to be exact for just one tooth out
of line.
View TheFridge's profile
TheFridge
10816 posts in 1724 days
#3 posted 05-21-2017 03:38 AM
Yup
Karda
#4 posted 05-21-2017 03:49 AM
ok thanks, how do I do that, never done that before and I don’t want to ruin the blade
View MrRon's profile
MrRon
5264 posts in 3481 days
#5 posted 05-21-2017 04:45 PM
How can a bent tooth stop the saw? The teeth have to run clear of the guides. Sounds like the guides are not set correctly. The flat of the blade should be the only area in contact with the guides.
Karda
#6 posted 05-21-2017 06:15 PM
poor choice of woods, when I was moving the wheels by hand to check the tracking the blade stopped. the bent tooth was catching on the plastic table insert
