Table Saw screaming, not humming
Forum topic by newbiewoodworker posted 11-19-2010 11:09 PM 1727 views 0 times favorited 8 replies Add to Favorites Watch
View newbiewoodworker's profile
newbiewoodworker
668 posts in 2793 days
11-19-2010 11:09 PM
I asked my grandfather to bring down the tablesaw, because I want to build atleast 1 cabinet for the shop. He said he would look at the dump, since people throw cabinets away all the time. However, if he cannot locate one, then I am going to build it. However, he said he is nervous about it “flying apart”, because its really making alot of noise. He said it seems to scream now that he put the new blade on.
I know from the one at school, although its slightly better (A PM2000 compared to a Craftsman table top from 1950-60.. :) ), it hums, it doesnt scream really.
But I was wondering if anyone knew what it could be…?
-- "Ah, So your not really a newbie, but a I betterbie."
8 replies so far
View DaddyZ's profile
DaddyZ
2475 posts in 3006 days
#1 posted 11-19-2010 11:16 PM
Does it need a good cleaning & some Oiling?
View brunob's profile
brunob
2277 posts in 4135 days
#2 posted 11-19-2010 11:20 PM
My guess is bearings just from the noise. If it’s bearings, it probably won’t fly apart but it will seize up. That could be big problems.
-- Bruce from Central New York...now, if you'll pardon me, I have some sawdust to make.
View childress's profile
childress
841 posts in 3508 days
#3 posted 11-19-2010 11:37 PM
”He said it seems to scream now that he put the new blade on.”
Some blades have BAD harmonics. They can have this annoying and deafening squeal.
Nothing to worry about, just annoying.
-- Childress Woodworks
newbiewoodworker
#4 posted 11-19-2010 11:52 PM
Okay: That might very well be, because, he bought the cheapo Sears Blades.. they were under $10…
Thanks, Ill pass it along, should it be the general concensus…
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3551 days
#5 posted 11-19-2010 11:54 PM
Why not put the old blade back on a retry if it still persists then it’s not the blade if it diapears then it most likely is the el cheapo blade.Alistair
View HokieMojo's profile
HokieMojo
2104 posts in 3694 days
#6 posted 11-19-2010 11:55 PM
I’m not saying the benchtop saw is ok. I couldn’t tell that without seeing it in person.
That being said, there is a different type of motor used in a benchtop saw compared to a cabinet saw. The benchtop will almost invariably be louder.
newbiewoodworker
#7 posted 11-20-2010 12:33 AM
No doubt. I know that the bench top is a Direct drive, and the Cabinet is, I think belt driven(But the motor tilts with the blade, and the teacher says the arbor is comming out of the motor… but I didnt see for myself…) So w/o a doubt, there will be a definate noise difference… but From when I have used my Grandfathers, it usually was not THAT loud… although someties it got annoying.
View Swede's profile
Swede
191 posts in 2984 days
#8 posted 11-20-2010 12:52 AM
1. Try a different blade.
2. Try running the saw without the blade on to see how loud it is.
3. Some blades are nosier than others especially if it has been resharpened.
-- Swede -- time to make some sawdust
