how to accurately cut leaxsand
Forum topic by RandyMarine posted 11-19-2010 07:54 PM 2341 views 0 times favorited 8 replies Add to Favorites Watch
View RandyMarine's profile
RandyMarine
236 posts in 3240 days
11-19-2010 07:54 PM
Topic tags/keywords: question
Hello All,
I am building a shadowbox for a friend, who’s father has just passed away. I have a great looking box with no front LOL. How do you cut lexsand without heat build up or is this not an issue…
Any help and advice would be greatly appreciated.
Thanks
-- Semper Fi, Randy Sr.
8 replies so far
RandyMarine
#1 posted 11-19-2010 08:07 PM
do I use a laminate blade or a fine tooth blade? and thank you
View rickf16's profile
rickf16
389 posts in 3452 days
#2 posted 11-19-2010 08:19 PM
They also make a cutter for lexan/plexi. Got mine from Lowes.
-- Rick
View Sawdust4Blood's profile
Sawdust4Blood
393 posts in 2892 days
#3 posted 11-19-2010 08:38 PM
I use either a lexan/plexi cutter or a jig saw since I can cut it without significant heat or worrying about it grabbing and becoming a projectile.
-- Greg, Severn MD
RandyMarine
#4 posted 11-19-2010 10:09 PM
thanks people…
If I use a jigsaw what TPI blade do I use.
View John Ormsby's profile
John Ormsby
1283 posts in 3608 days
#5 posted 11-19-2010 10:27 PM
I run a standard fine tooth steel plywood backwards on the tablesaw to cut plastics in a straight line. The router does all of the curved work.
-- Oldworld, Fair Oaks, Ca
View FirehouseWoodworking's profile
703 posts in 3144 days
#6 posted 11-20-2010 03:25 AM
Don’t know if others have encountered this problem or if it is that I’m using the wrong blade. I have sometimes have had to cut 1/4” plexiglass (not sure if it was Lexan or not) but to prevent melting both pieces back together, I would cut partly into the piece then flip it over and cut partly into the plexiglass from the other side. Then merely snap the piece off and clean the edge up with sandpaper and/or a propane torch.
Never had any problem with chipping. Whenever I would try to cut all the way through in one pass, I would get chipping.
Like I said, not sure if it was the blade or the operator.
-- Dave; Lansing, Kansas
View JimDaddyO's profile
JimDaddyO
528 posts in 2950 days
#7 posted 11-20-2010 03:44 PM
I use a straightedge and a utility knife. Score the lexan 4 or 5 times to get a nice groove, clamp it to the edge of a table with a board on the top so the score is on the edge of the table, and give it a sharp snap down. Very little sanding to the edge to clean it up.
-- my blog: http://watertoneworkshop.blogspot.ca/ my You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA?view_as=subscriber
RandyMarine
#8 posted 11-20-2010 10:00 PM
Thanks All,
I tried scoring it…and couldn’t get it to break. I tried it on my table saw and it did grab a good bit and scared the $h!t out of me. So I grabbed my jig saw and put a 22 TPI metal blade and got a beautiful cut. I did all this on test pieces. So I measured, marked, and cut the real piece….a 1/4 of an inch too small…...Well off to HD to get another piece.
I appreciate all the input and advice. Shows that there are still great LJ’s out there!
