I need help with a wood filler
Forum topic by CantBurn posted 11-19-2010 04:50 AM 1068 views 0 times favorited 4 replies Add to Favorites Watch
View CantBurn's profile
CantBurn
69 posts in 2699 days
11-19-2010 04:50 AM
Topic tags/keywords: filler putty glue oil
I have a red wood next to a light wood. I have a gap that needs to be filled, I am thinking about favoring to the darker color. I have seen products like Timbermate™. I also will be apply an oil to this wood, not a stain. So your opinions, what is the best method to fill? Putty? Sawdust? Glue? And which of these is ok for an oil?
-- Chris-Woodstock, Illinois
View Brandon Hintz's profile
Brandon Hintz
53 posts in 2881 days
#1 posted 11-19-2010 05:08 AM
I had a similar problem on a bar I built, where I had red oak meeting Paduck. I used famowood’s red oak filler and then sanded the whole bartop but it all depends on your design
-- Potential is limited only by imagination
CantBurn
#2 posted 11-19-2010 05:45 AM
Thank you, I will check them out. And you had a decent experience with them and with oil?
View DrDirt's profile
DrDirt
4418 posts in 3615 days
#3 posted 11-19-2010 07:15 AM
THis is one you need Charles Neil to weigh in on….he has coloring down!
View wisno's profile
wisno
88 posts in 2884 days
#4 posted 11-25-2010 08:05 AM
How big is your gap?
If it is big enough you better insert a piece of wood to fix it.
If it small the you can do with wood putty. You need to color your putty so it matches with your finishing color.
Good luck
Wisno
-- http://www.wisnofurniturefinishing.com/
