Simple lathe device based on KWB drill stand
Forum topic by woodbird posted 05-19-2017 12:03 PM 675 views 0 times favorited 4 replies Add to Favorites Watch
View woodbird's profile
woodbird
9 posts in 613 days
05-19-2017 12:03 PM
Hi guys !
I would like to show you my simple device for small lather works. I have done it from KWB drill stand and three clamps. I am also using it as sharpening, grinding and polishing rotary tool. It is not for power works, of course, but for small projects it is good. Hope someone will find this my humble inventory useful.
Here you can see device itself and final result made from apple-tree and finished with Danish oil.
View Gilley23's profile
Gilley23
489 posts in 621 days
#1 posted 05-19-2017 04:25 PM
Well would ya look at that….pretty cool! And doesn’t take up any room when not needed. Are you selling these?
woodbird
9 posts in 613 days
#2 posted 05-19-2017 05:16 PM
Thank you, Gilley23 !
You are right about free space – I have no too much at my balcony. I have done it for myself, but you can purchase drill stand at Amazon, for example, or may be cheaper anywhere, and I will give you sketch and instructions how to build it.
Gilley23
#3 posted 05-19-2017 07:51 PM
Ohhh I see, I thought that you made the stand as well. What did you use to hold the stock in place? Are you using the drill stand legs for the tool rest?
woodbird
9 posts in 613 days
#4 posted 05-20-2017 03:03 PM
Please look at this additional shots and you will understand this simple construction. Stock is fixing between flat wood drill with removed cutting edge and shaped bolt. Two stands at drill side I have done myself from rectangular aluminium tube.
The good practice will be to drill two small holes on both sides of stock and one diametrical cut at the drill side to make fixing more easy.
