Rikon 10-324 Blade Tension is screwy
Forum topic by Hard_as_Wood posted 05-18-2017 09:33 PM 593 views 0 times favorited 4 replies Add to Favorites Watch
View Hard_as_Wood's profile
Hard_as_Wood
31 posts in 1114 days
05-18-2017 09:33 PM
I put on my TW 111” 3/4” blade and got all my rollers setup where I want them.
I tension the blade and then I’m as loose as I can go but the knob on top is tight. Shouldn’t turning the knob on top to loosen the tension get looser? Mine gets tighter. It actually gets looser when I tighten the knob.
Makes no sense.
When I tension it up, I can hear the blade kind of pop tight, it sounds awful and I’m not getting the deflection out of it like I should, it’s tight and stiff.
I should check the size. I’m assuming they gave me a 111” maybe it’s smaller.
Don’t know where to go from here….
-- Ciao!
View WhyMe's profile
WhyMe
1061 posts in 1733 days
#1 posted 05-18-2017 09:47 PM
Clockwise on the tension knob should raise the top wheel (tighten blade). Counter clockwise should lower the top wheel (loosen blade). Tighten with quick release lever in the on position.
Hard_as_Wood
#2 posted 05-18-2017 09:50 PM
Correct, it moves that way, but I’m down all the way I can go and it still seems excessively tight.
Is their anything I can adjust so I can lower it even more?
-- Ciao!
WhyMe
#3 posted 05-19-2017 12:49 AM
Apparently you got it loose enough to get the blade on so I’m at a loss as to what the problem is. Did you verify the blade length?
Hard_as_Wood
#4 posted 05-19-2017 11:46 AM
Yes, when the tension is off then the blade came off and on very easily.
It’s when I put the blade tension on and then try to loosen the tension is when I run into problems. I went down again this morning and looked at it again and I think I might be blowing this out of proportion. I did run it yesterday several times to check for blade tracking and all was good.
According to Alex Snodgrass video https://youtu.be/wGbZqWac0jU?list=PL4-DbKF0dMcCQxNI44XTrpUjZtafrFcmE on how to setup a BS for resawing I have the correct tension on the blade and this time it didn’t make those odd popping sounds… I think I’m nervous, I don’t want to ruin my bs
whats the worse that could happen? blade brakes?
-- Ciao!
