Input needed re aftermarket TS fence
Forum topic by kit posted 11-18-2010 05:07 PM 983 views 0 times favorited 3 replies Add to Favorites Watch
View kit's profile
kit
24 posts in 2798 days
11-18-2010 05:07 PM
On my old 8” Delta Rockwell 34-600 TS, squaring the fence to the blade is real challenge. I have tinkered with it to no avail. Any suggestions?
Is an aftermarket fence the way to go? Is there one that works with my saw & is it somehow “adjustable” to facilitate squaring up the fence to the blade?
Also, cranking the blade to 45-degrees is getting harder & harder and if there is a trick solution, I would sure appreciate hearing it. Thank you.
Kit
-- Kit, Paso Robles, CA, http://www.WoodworkerKit.com
3 replies so far
View TheDane's profile
TheDane
5448 posts in 3690 days
#1 posted 11-18-2010 05:43 PM
A lot of folks really like the Delta T2 … others like the Vega fences, etc. I went with a Shop Fox ( http://lumberjocks.com/reviews/840 ) ... easy to install and rock solid.
As for the cranking problem, check to make sure you don’t have sawdust caked in the works. This happened on my Jet, and all it took was a good cleaning and lube to fix it.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3134 days
#2 posted 11-18-2010 06:58 PM
I love my T2. What more can I say.
View shipwright's profile
shipwright
7992 posts in 2825 days
#3 posted 11-18-2010 07:25 PM
UNIFENCE !
