Inside Box, to finish or not to finish
Forum topic by bushmaster posted 05-18-2017 05:38 PM 770 views 0 times favorited 14 replies Add to Favorites Watch
View bushmaster's profile
bushmaster
3424 posts in 2519 days
05-18-2017 05:38 PM
I am just in the finishing stage of finishing a couple boxes for gifts, So do I apply finish to the inside of the box, would like to, but concerned with the smell that can linger in a closed space. I would use a fast curing spray finish, such as Krylon spray lacquer. Is this advisable. I see lots of fantastic boxes entered on this site, would like your opinions and secrets.
Thanks Brian, the Bushman
-- Brian - Hazelton, British Columbia
14 replies so far
View jmartel's profile
jmartel
8279 posts in 2387 days
#1 posted 05-18-2017 05:42 PM
Could use shellac. The smell goes away pretty quickly.
5234 posts in 2730 days
#2 posted 05-18-2017 06:07 PM
Shellac, any waterborne finish, or lacquer should be fine. The lingering odor problem is typically associated with oil based finishes.
View waho6o9's profile
waho6o9
8539 posts in 2814 days
#3 posted 05-18-2017 06:12 PM
Shellac and or wax works for me.
View DrDirt's profile
DrDirt
4526 posts in 3979 days
#4 posted 05-18-2017 07:27 PM
I spray lacquer for boxes inside and out…. since I expect that inevitably something sticky/nasty will be put in the box… or will sit in the sun on a dresser and melt a lipstick.
NO oils though… that takes forever to cure and stop smelling. But Lacquer and Shellac are great.
bushmaster
#5 posted 05-18-2017 08:52 PM
Thanks for the advice, Will go ahead with the lacquer as I have some, agree with things in the box that can get it marked or dirty, they will not receive them till towards the end of June, so will be well aired by then.
View BenDupre's profile
BenDupre
690 posts in 725 days
#6 posted 05-18-2017 08:57 PM
My woodshop teacher taught the rule was “whatever you do to finish one side, do it to the other” because.. moisture. So i would spray the inside and give it all the time it needs to cure out. Good Luck
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
View Rich's profile
Rich
4000 posts in 826 days
#7 posted 05-18-2017 09:05 PM
Not a finish per se, but flocking can provide a nice finishing touch. Just a thought — it might not be the sort of interior you are looking for though.
If you want finished wood, the shellac and lacquer recommendations above are good ones.
View AandCstyle's profile
AandCstyle
3185 posts in 2494 days
#8 posted 05-18-2017 09:25 PM
Brian, here is another vote for lacquer, but I am partial to Deft lacquer. FWIW
-- Art
View Jim Jakosh's profile
Jim Jakosh
21961 posts in 3342 days
#9 posted 05-18-2017 09:40 PM
Hi Brian,
Lacquer would be good. Danish oil would work too. I use Danish oil before the lacquer every time….it makes the grain “pop” .
Just don’t use oil based poly.That will keep the smell and be objectionable!
Cheer, Jim
MrUnix
7106 posts in 2436 days
#10 posted 05-18-2017 10:12 PM
Ok, dissenting voice here for oil based poly :)
I have a couple of Cedar lidded boxes I turned a while back, and finished with oil based poly inside and out. If you take the lid off the box, all you smell is Cedar. They were allowed to cure for several weeks though. The poly doesn’t smell like poly forever :)
I do use Lacquer as well, and Danish oil. And I always finish the inside the same as the outside, even when I plan to line them with something like felt also.
View kiefer's profile
kiefer
5623 posts in 2904 days
#11 posted 05-19-2017 02:22 AM
I use linseed oil and wax or poly inside and out I hate lacquer then spray with Febreze after the finish has cured .
Klaus
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
View crowie's profile
crowie
2812 posts in 2188 days
#12 posted 05-19-2017 10:39 AM
Brain, I maybe a little late but you could do a test box, say, using a cardboard shoe box or similar and see how the smell issue becomes an problem…just a thought…
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
bushmaster
#13 posted 05-19-2017 01:36 PM
Kiefer, Febreze, Will have to try that, I think that is a Klaus original, always thinking beyond and coming up with great projects and ideas. Thanks.
View EricTwice's profile
EricTwice
248 posts in 770 days
#14 posted 05-19-2017 02:19 PM
Always finish both sides, it makes the wood more stable and prevents warping. l would use lacquer or shellac. Just because they are fast, easy and no fuss.
but almost anything will work, what do you have? use that.
-- nice recovery, They should pay extra for that mistake, Eric E.
