How can the outfeed table on a 6" Delta jointer be trued up?
Forum topic by Mark Shymanski posted 11-18-2010 07:35 AM 1663 views 0 times favorited 2 replies Add to Favorites Watch
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3616 days
11-18-2010 07:35 AM
Topic tags/keywords: question jointer
Hello All,
I know this topic was covered here already and I will continue looking for it but so far haven’t been able to find a solution. The situation is that the out feed table on my Delta jointer droops about 13/100ths of an inch so I am unable to properly joint my boards.
I tried to adjust the gibs and was able to lift the table even, but then could not get it to stay there the table would still droop, less but still droop. It almost seems like there should be shims or something on the dovetails to raise up the outer end of the table…where or how I would put them in is I guess the question I am looking to answer. Any help is sure appreciated!
Mark
2 replies so far
View TheDane's profile
TheDane
5365 posts in 3566 days
#1 posted 11-19-2010 04:55 AM
You probably need to use some shims … you can buy shims from a number of online sources, but some use aluminum strips cut from a soda or beer can.
This might help … http://www.craftkb.com/Uwe/Forum.aspx/woodworking/17256/How-to-shim-jointer-outfeed-table
Mark Shymanski
#2 posted 11-20-2010 07:12 AM
Thanks for the recommendation about shims.
I eventually got it sorted out but I will start to look around for some shim material. One of the downsides about not drinking a lot of pop (or other canned beverages) is that I don’t have any cans kicking around to scavenge for shims :-)
